I am used to the old CoRE, never had a problem. Now it seems I can’t figure this out, or maybe something else is wrong? I can turn the plug on and off manually in the app, but cannot figure out why the piston is not turning it off and on.
Every XX minutes (currently set at 30 seconds for testing purposes) I want the plug to either turn on, or off - basically to alternate charging times of something plugged in 24/7 to limit battery damage.
The plug is not turning on or off.
11/5/2020, 12:35:08 PM +125ms
+0ms ╔Received event [Home].time = 1604597709031 with a delay of -907ms
+71ms ║RunTime Analysis CS > 19ms > PS > 39ms > PE > 14ms > CE
+73ms ║Runtime (37764 bytes) successfully initialized in 39ms (v0.3.110.20191009) (72ms)
+93ms ║║Comparison (enum) off is (string) on = false (1ms)
+95ms ║║Condition #3 evaluated false (11ms)
+96ms ║║Condition group #2 evaluated false (state did not change) (12ms)
+106ms ║║Comparison (enum) off is (string) off = true (2ms)
+107ms ║║Condition #7 evaluated true (9ms)
+108ms ║║Condition group #6 evaluated true (state did not change) (10ms)
+111ms ║║Cancelling statement #8’s schedules…
+140ms ║║Executed physical command [Alarm Panel Charger].on() (24ms)
+141ms ║║Executed virtual command [Alarm Panel Charger].setSwitch (27ms)
+145ms ║╚Execution stage complete. (71ms)
+147ms ║Setting up scheduled job for Thu, Nov 5 2020 @ 12:35:39 PM EST (in 30.76s)
+153ms ╚Event processed successfully (153ms)
11/5/2020, 12:34:38 PM +126ms
+0ms ╔Received event [Home].time = 1604597679031 with a delay of -905ms
+58ms ║RunTime Analysis CS > 15ms > PS > 33ms > PE > 10ms > CE
+60ms ║Runtime (37764 bytes) successfully initialized in 33ms (v0.3.110.20191009) (59ms)
+61ms ║╔Execution stage started
+78ms ║║Comparison (enum) off is (string) on = false (2ms)
+79ms ║║Condition #3 evaluated false (10ms)
+80ms ║║Condition group #2 evaluated false (state did not change) (11ms)
+90ms ║║Comparison (enum) off is (string) off = true (2ms)
+91ms ║║Condition #7 evaluated true (8ms)
+92ms ║║Condition group #6 evaluated true (state did not change) (9ms)
+94ms ║║Cancelling statement #8’s schedules…
+105ms ║║Executed physical command [Alarm Panel Charger].on() (7ms)
+106ms ║║Executed virtual command [Alarm Panel Charger].setSwitch (8ms)
+109ms ║╚Execution stage complete. (48ms)
+110ms ║Setting up scheduled job for Thu, Nov 5 2020 @ 12:35:09 PM EST (in 30.795s)
+117ms ╚Event processed successfully (117ms)
