Seems the calculations for start date are still coming up with yesterday? Even though the start time is showing correctly?
+2ms
╔Received event [gCal Mark Work Schedule Events].eventSummary = Next GCal Event: Work Schedule
+2ms
╔Calendar: Work Schedule
+2ms
╔Event Start: Sat, Dec 09 09:00 AM
+2ms
╔Event End: Sat, Dec 09 06:00 PM
+2ms
╔ with a delay of 118ms
+112ms
║RunTime Analysis CS > 30ms > PS > 53ms > PE > 29ms > CE
+119ms
║Runtime (42624 bytes) successfully initialized in 53ms (v0.2.0ff.20171129) (117ms)
+120ms
║╔Execution stage started
+130ms
║║Comparison (enum) closed is (string) closed = true (1ms)
+131ms
║║Condition #17 evaluated true (7ms)
+135ms
║║Comparison (string) Next GCal Event: Work Schedule
+135ms
║║Calendar: Work Schedule
+135ms
║║Event Start: Sat, Dec 09 09:00 AM
+135ms
║║Event End: Sat, Dec 09 06:00 PM
+135ms
║║ is_not (string) No events found = true (0ms)
+136ms
║║Condition #29 evaluated true (4ms)
+137ms
║║Condition group #1 evaluated true (state did not change) (14ms)
+138ms
║║Cancelling statement #2’s schedules…
+153ms
║║Calculating (integer) 63 + (integer) 12 >> (integer) 75
+157ms
║║Calculating (string) Dec 09 + (string) 2017 >> (string) Dec 09 2017
+163ms
║║Executed virtual command [gCal Mark Work Schedule Events].setVariable (4ms)
+170ms
║║Calculating (integer) 63 + (integer) 19 >> (integer) 82
+175ms
║║Executed virtual command [gCal Mark Work Schedule Events].setVariable (2ms)
+177ms
║║Cancelling statement #25’s schedules…
+185ms
║║Calculating (string) Fri, Dec 8 2017 + (string) , >> (string) Fri, Dec 8 2017,
+187ms
║║Calculating (string) Fri, Dec 8 2017, + (string) 9:00:00 AM AKST >> (string) Fri, Dec 8 2017, 9:00:00 AM AKST
+192ms
║║Executed virtual command [Scene LR Daytime].setState (0ms)
+199ms
+202ms
+208ms
║║Executed virtual command [Scene LR Daytime].waitForDateTime (2ms)
+421ms
║║Executed physical command [Scene LR Daytime].on() (212ms)
+422ms
║║Executed [Scene LR Daytime].on (213ms)
+423ms
║╚Execution stage complete. (304ms)
+430ms
╚Event processed successfully (430ms)
12/9/2017, 7:43:10 AM +38ms
+1ms
+1ms
+1ms
+1ms
+1ms
╔ with a delay of 80ms
+64ms
║RunTime Analysis CS > 13ms > PS > 25ms > PE > 26ms > CE
+71ms
║Runtime (42622 bytes) successfully initialized in 25ms (v0.2.0ff.20171129) (69ms)
+72ms
+83ms
+84ms
║║Condition #17 evaluated true (8ms)
+88ms
+88ms
+88ms
+88ms
+88ms
║║ is_not (string) No events found = true (1ms)
+89ms
+90ms
+92ms
+100ms
+104ms
+108ms
+115ms
+120ms
║║Executed virtual command [gCal Mark Work Schedule Events].setVariable (1ms)
+122ms
+133ms
+135ms
+139ms
+147ms
+149ms
+152ms
║║Executed virtual command [Scene LR Daytime].waitForDateTime (0ms)
+292ms
║║Executed physical command [Scene LR Daytime].on() (139ms)
+293ms
║║Executed [Scene LR Daytime].on (140ms)
+295ms
║╚Execution stage complete. (223ms)
+304ms
╚Event processed successfully (304ms)
