(My piston executed even though my wife’s phones present and turned off the lights)
(The expected behavior is that if front door sensor or garage door sensor changes to closed then wait 10 minutes and see if either of us are home. If we aren’t home, I want the lights to turn off.)
(I can’t seem to figure out why my lights turned off when my wife was home and ST said she was present and never left.)
**5) Attach any logs
( 11/28/2018, 12:07:01 PM +529ms
+1ms ╔Received event [Home].time = 1543428422684 with a delay of -1156ms
+286ms ║RunTime Analysis CS > 88ms > PS > 150ms > PE > 48ms > CE
+289ms ║Runtime (38765 bytes) successfully initialized in 150ms (v0.3.104.20180323) (287ms)
+291ms ║╔Execution stage started
+341ms ║║Comparison (enum) not present is (string) not present = true (3ms)
+344ms ║║Condition #6 evaluated true (17ms)
+346ms ║║Condition group #5 evaluated true (state did not change) (20ms)
+351ms ║║Cancelling statement #7’s schedules…
+372ms ║║Skipped execution of physical command [Entertainment stand].off([]) because it would make no change to the device. (4ms)
+374ms ║║Executed [Entertainment stand].off (8ms)
+402ms ║║Executed physical command [Entertainment Stand Outlet].off() (23ms)
+405ms ║║Executed [Entertainment Stand Outlet].off (27ms)
+424ms ║║Executed physical command [Front door light].off() (13ms)
+425ms ║║Executed [Front door light].off (17ms)
+442ms ║║Executed physical command [Front door light].off() (13ms)
+444ms ║║Executed [Front door light].off (16ms)
+467ms ║║Executed physical command [Garage door light].off() (20ms)
+470ms ║║Executed [Garage door light].off (23ms)
+486ms ║║Executed physical command [Garage door light].off() (12ms)
+488ms ║║Executed [Garage door light].off (15ms)
+494ms ║║Skipped execution of physical command [Hue color lamp 1].off([]) because it would make no change to the device. (3ms)
+495ms ║║Executed [Hue color lamp 1].off (5ms)
+503ms ║║Skipped execution of physical command [Hue go 1].off([]) because it would make no change to the device. (3ms)
+504ms ║║Executed [Hue go 1].off (7ms)
+512ms ║║Skipped execution of physical command [Hue go 2].off([]) because it would make no change to the device. (3ms)
+514ms ║║Executed [Hue go 2].off (7ms)
+530ms ║║Executed physical command [Kitchen lights].off() (12ms)
+531ms ║║Executed [Kitchen lights].off (15ms)
+547ms ║║Executed physical command [Kitchen lights].off() (11ms)
+549ms ║║Executed [Kitchen lights].off (16ms)
+556ms ║║Skipped execution of physical command [Living room floor lamp].off([]) because it would make no change to the device. (4ms)
+558ms ║║Executed [Living room floor lamp].off (6ms)
+591ms ║║Executed physical command [tree outlet].off() (29ms)
+593ms ║║Executed [tree outlet].off (33ms)
+600ms ║╚Execution stage complete. (309ms)
+603ms ╚Event processed successfully (602ms)
11/28/2018, 11:57:02 AM +526ms
+1ms ╔Received event [garage door].contact = closed with a delay of 1240ms
+121ms ║RunTime Analysis CS > 27ms > PS > 57ms > PE > 38ms > CE
+124ms ║Runtime (38768 bytes) successfully initialized in 57ms (v0.3.104.20180323) (122ms)
+141ms ║║Comparison (enum) closed changes_to (string) closed = true (1ms)
+144ms ║║Cancelling condition #2’s schedules…
+145ms ║║Condition #2 evaluated true (14ms)
+146ms ║║Cancelling condition #1’s schedules…
+148ms ║║Condition group #1 evaluated true (state changed) (16ms)
+151ms ║║Cancelling statement #3’s schedules…
+155ms ║║Executed virtual command wait (1ms)
+157ms ║║Requesting a wake up for Wed, Nov 28 2018 @ 12:07:02 PM CST (in 600.0s)
+163ms ║╚Execution stage complete. (37ms)
+164ms ║Setting up scheduled job for Wed, Nov 28 2018 @ 12:07:02 PM CST (in 599.994s)
+208ms ╚Event processed successfully (208ms))
