So I have the hallway light set to turn on and off when the bedroom door opens and closes but I dont want it to turn off if the light was turned on manually beforehand
It works sometimes.
The problem is if you close the door too fast it wont turn off the light.
is there a setting or something I need to change to make this work more reliably? I tried parallelism and async and override but none of those seem to make a difference
