Having trouble figuring out how to turn off plug after 1 minute after having it turn on. I assume I would use a while loop but I’m not sure where I should place the while loop and how to get the compare the condition of 1 minute of time passing. I’m not a very good programmer so this is a bit above my head.
Trying to create a piston that will turn on a switch every 10 minutes for 1 minute then shut it off.
Can’t automate the turning off.
| +2ms | ╔Received event [Home].time = 1553607271740 with a delay of -383ms |
| +170ms | ║RunTime Analysis CS > 56ms > PS > 101ms > PE > 13ms > CE |
| +172ms | ║Runtime (36213 bytes) successfully initialized in 101ms (v0.3.10a.20190223) (169ms) |
| +174ms | ║╔Execution stage started |
| +189ms | ║║Cancelling statement #2’s schedules… |
| +717ms | ║║Executed physical command [Hot Water Recirculator].on() (522ms) |
| +718ms | ║║Executed [Hot Water Recirculator].on (525ms) |
| +724ms | ║╚Execution stage complete. (551ms) |
| +726ms | ║Setting up scheduled job for Tue, Mar 26 2019 @ 9:44:31 AM EDT (in 599.657s) |
| +735ms | ╚Event processed successfully (735ms) |
| 3/26/2019, 9:24:30 AM +106ms | |
| +0ms | ╔Received event [Home].time = 1553606671740 with a delay of -1635ms |
| +89ms | ║RunTime Analysis CS > 19ms > PS > 58ms > PE > 13ms > CE |
| +92ms | ║Runtime (36211 bytes) successfully initialized in 58ms (v0.3.10a.20190223) (90ms) |
| +93ms | ║╔Execution stage started |
| +107ms | ║║Cancelling statement #2’s schedules… |
| +590ms | ║║Executed physical command [Hot Water Recirculator].on() (477ms) |
| +591ms | ║║Executed [Hot Water Recirculator].on (481ms) |
| +595ms | ║╚Execution stage complete. (503ms) |
| +597ms | ║Setting up scheduled job for Tue, Mar 26 2019 @ 9:34:31 AM EDT (in 601.038s) |
| +608ms | ╚Event processed successfully (608ms) |
Any help would be much appreciated.
