Shed WLED Off piston will not turn off at proper time.
20 minutes before sunset, Garage WLED On and Shed WLED On pistons turn on. 11:00pm, Garage WLED Off and Shed WLED Off pistons turn off.
Both pistons turned on, only Garage turned off. The Garage piston has the proper log of turning on and turning off at the proper times. The Shed has the proper log of turning on, and has nothing at the turn-off time.
10/23/2020, 10:59:59 PM +153ms
+1ms âReceived event [Home].time = 1603508400000 with a delay of -847ms
+105ms âRunTime Analysis CS > 29ms > PS > 55ms > PE > 21ms > CE
+108ms âRuntime (38058 bytes) successfully initialized in 55ms (v0.3.110.20191009) (105ms)
+109ms ââExecution stage started
+125ms ââCancelling statement #6âs schedulesâŚ
+139ms ââExecuted virtual command executePiston (10ms)
+154ms ââExecuted virtual command executePiston (10ms)
+157ms ââExecution stage complete. (49ms)
+159ms âSetting up scheduled job for Sat, Oct 24 2020 @ 5:32:00 PM EDT (in 66720.688s), with 1 more job pending
+165ms âEvent processed successfully (165ms)
10/23/2020, 5:31:59 PM +59ms
+1ms âReceived event [Home].time = 1603488720000 with a delay of -941ms
+64ms âRunTime Analysis CS > 23ms > PS > 32ms > PE > 8ms > CE
+66ms âRuntime (38056 bytes) successfully initialized in 32ms (v0.3.110.20191009) (65ms)
+67ms ââExecution stage started
+96ms ââCancelling statement #2âs schedulesâŚ
+107ms ââExecuted virtual command executePiston (7ms)
+119ms ââExecuted virtual command executePiston (6ms)
+123ms ââExecution stage complete. (55ms)
+126ms âSetting up scheduled job for Fri, Oct 23 2020 @ 11:00:00 PM EDT (in 19680.816s), with 1 more job pending
+138ms âEvent processed successfully (137ms)
