I want my lights to turn on for 15 minutes when my door opens but it always fails
1.Turn garden lights on from sunset till 00:00
2. turn off garden lights after 00:00
3. turn on garden lights when door opens from 00:00 till sunrise
4. turn lights back off after 15 minuts
5. after sunrise do nothing with the lights when door opens
lights do not turn on at sunset, do not turn off at 00:00
28-6-2020 00:52:08 +635ms
+0ms ╔Received event [Seppe & Jaimy’s Home].test = 1593298328632 with a delay of 2ms
+72ms â•‘RunTime Analysis CS > 20ms > PS > 21ms > PE > 31ms > CE
+75ms â•‘Runtime (38296 bytes) successfully initialized in 21ms (v0.3.10f.20190822) (73ms)
+76ms â•‘â•”Execution stage started
+115ms ║║Comparison (time) 3128717 is_between (time) 0 … (datetime) 1593315360000 = true (9ms)
+116ms â•‘â•‘Time restriction check passed
+118ms ║║Cancelling condition #2’s schedules…
+119ms â•‘â•‘Condition #2 evaluated true (38ms)
+127ms â•‘â•‘Condition #3 evaluated false (7ms)
+128ms â•‘â•‘Condition group #1 evaluated false (state did not change) (47ms)
+144ms ║║Comparison (time) 3128767 is_between (datetime) 1593374700000 … (time) 86340000 = false (8ms)
+146ms ║║Cancelling condition #9’s schedules…
+147ms â•‘â•‘Condition #9 evaluated false (15ms)
+148ms ║║Cancelling condition #8’s schedules…
+149ms â•‘â•‘Condition group #8 evaluated false (state changed) (17ms)
+159ms â•‘â•‘Comparison (time) 3128785 is_after (datetime) 1593315360000 = false (5ms)
+160ms ║║Cancelling condition #15’s schedules…
+161ms â•‘â•‘Condition #15 evaluated false (11ms)
+163ms ║║Cancelling condition #14’s schedules…
+164ms â•‘â•‘Condition group #14 evaluated false (state changed) (13ms)
+166ms ║╚Execution stage complete. (91ms)
+168ms ╚Event processed successfully (168ms)
27-6-2020 23:20:48 +437ms
+1ms ╔Received event [Seppe & Jaimy’s Home].test = 1593292848434 with a delay of 2ms
+92ms â•‘Runtime (38215 bytes) successfully initialized in 24ms (v0.3.10f.20190822) (89ms)
+93ms â•‘â•”Execution stage started
+173ms â•‘â•‘Executed [Tuinlampen].on (4ms)
+184ms ║╚Execution stage complete. (91ms)
+186ms ╚Event processed successfully (186ms)
27-6-2020 23:13:11 +218ms
+0ms â•”Received event [Achterdeur].contact = closed with a delay of 71ms
+52ms â•‘Runtime (38202 bytes) successfully initialized in 15ms (v0.3.10f.20190822) (51ms)
+53ms â•‘â•”Execution stage started
+106ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+109ms ║╚Execution stage complete. (55ms)
+110ms ╚Event processed successfully (110ms)
27-6-2020 23:13:07 +489ms
+0ms â•”Received event [Achterdeur].contact = open with a delay of 86ms
+53ms â•‘Runtime (38200 bytes) successfully initialized in 16ms (v0.3.10f.20190822) (51ms)
+54ms â•‘â•”Execution stage started
+102ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+104ms ║╚Execution stage complete. (51ms)
+105ms ╚Event processed successfully (105ms)
27-6-2020 23:08:42 +210ms
+1ms â•”Received event [Achterdeur].contact = closed with a delay of 81ms
+62ms â•‘Runtime (38202 bytes) successfully initialized in 20ms (v0.3.10f.20190822) (61ms)
+63ms â•‘â•”Execution stage started
+119ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+122ms ║╚Execution stage complete. (59ms)
+123ms ╚Event processed successfully (123ms)
27-6-2020 23:08:40 +166ms
+1ms â•”Received event [Achterdeur].contact = open with a delay of 82ms
+61ms â•‘Runtime (38200 bytes) successfully initialized in 16ms (v0.3.10f.20190822) (58ms)
+62ms â•‘â•”Execution stage started
+121ms â•‘â•‘Executed [Tuinlampen].on (4ms)
+124ms ║╚Execution stage complete. (62ms)
+125ms ╚Event processed successfully (125ms)
27-6-2020 23:06:13 +382ms
+1ms â•”Received event [Achterdeur].contact = closed with a delay of 73ms
+50ms â•‘Runtime (38202 bytes) successfully initialized in 15ms (v0.3.10f.20190822) (48ms)
+51ms â•‘â•”Execution stage started
+215ms â•‘â•‘Executed [Tuinlampen].on (116ms)
+218ms ║╚Execution stage complete. (167ms)
+219ms ╚Event processed successfully (219ms)
27-6-2020 23:06:11 +202ms
+1ms â•”Received event [Achterdeur].contact = open with a delay of 86ms
+58ms â•‘Runtime (38200 bytes) successfully initialized in 20ms (v0.3.10f.20190822) (56ms)
+59ms â•‘â•”Execution stage started
+112ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+114ms ║╚Execution stage complete. (55ms)
+115ms ╚Event processed successfully (115ms)
27-6-2020 23:04:35 +997ms
+1ms â•”Received event [Achterdeur].contact = closed with a delay of 87ms
+54ms â•‘Runtime (38202 bytes) successfully initialized in 16ms (v0.3.10f.20190822) (52ms)
+55ms â•‘â•”Execution stage started
+105ms â•‘â•‘Executed [Tuinlampen].on (4ms)
+108ms ║╚Execution stage complete. (52ms)
+109ms ╚Event processed successfully (109ms)
27-6-2020 23:04:28 +709ms
+1ms â•”Received event [Achterdeur].contact = open with a delay of 98ms
+50ms â•‘Runtime (38200 bytes) successfully initialized in 15ms (v0.3.10f.20190822) (48ms)
+116ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+118ms ║╚Execution stage complete. (67ms)
+119ms ╚Event processed successfully (119ms)
27-6-2020 23:02:48 +897ms
+1ms â•”Received event [Achterdeur].contact = closed with a delay of 78ms
+61ms â•‘Runtime (38202 bytes) successfully initialized in 23ms (v0.3.10f.20190822) (59ms)
+115ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+117ms ║╚Execution stage complete. (55ms)
27-6-2020 23:02:47 +689ms
+1ms â•”Received event [Achterdeur].contact = open with a delay of 84ms
+61ms â•‘Runtime (38200 bytes) successfully initialized in 21ms (v0.3.10f.20190822) (59ms)
+118ms â•‘â•‘Executed [Tuinlampen].on (4ms)
+120ms ║╚Execution stage complete. (58ms)
+121ms ╚Event processed successfully (121ms)
27-6-2020 23:02:47 +277ms
+1ms â•”Received event [Achterdeur].contact = closed with a delay of 72ms
+59ms â•‘Runtime (38202 bytes) successfully initialized in 20ms (v0.3.10f.20190822) (57ms)
+60ms â•‘â•”Execution stage started
+118ms ║╚Execution stage complete. (58ms)
+120ms ╚Event processed successfully (120ms)
27-6-2020 23:02:33 +907ms
+1ms â•”Received event [Achterdeur].contact = open with a delay of 92ms
+50ms â•‘Runtime (38200 bytes) successfully initialized in 16ms (v0.3.10f.20190822) (48ms)
+101ms â•‘â•‘Executed [Tuinlampen].on (5ms)
+103ms ║╚Execution stage complete. (52ms)
+104ms ╚Event processed successfully (104ms)
27-6-2020 23:02:33 +373ms
+59ms â•‘Runtime (38202 bytes) successfully initialized in 21ms (v0.3.10f.20190822) (57ms)
+109ms â•‘â•‘Executed [Tuinlampen].on (4ms)
+111ms ║╚Execution stage complete. (52ms)
+112ms ╚Event processed successfully (112ms)
27-6-2020 23:02:20 +508ms
+1ms â•”Received event [Achterdeur].contact = open with a delay of 115ms
+46ms â•‘Runtime (38206 bytes) successfully initialized in 16ms (v0.3.10f.20190822) (45ms)
+48ms â•‘â•”Execution stage started
+98ms â•‘â•‘Executed [Tuinlampen].on (3ms)
+100ms ║╚Execution stage complete. (53ms)
+102ms ╚Event processed successfully (101ms)
