Turning Off Multiple Items
I want to turn off 10 devices all at the same time
At a specific time all items turn off
Some devices turn off, others do not. I have tried splitting the list with a pause, but no luck.
(UPLOAD YOUR IMAGE HERE)
Do you have logs for the running?
Have you looked at command execution delay for this piston?
The logs only state the command fired, but nothing reacted.
Since my original post, I added a refresh() prior to the turn-off command and removed the wait delay, it seems to have cured the issue.
You mention a command execution delay, where is that set?
If a refresh and turn off helped, maybe turning off command optimization will help. It’s under Piston Settings > Command Optimization.
Not seeing that, is it available in HE?
In piston edit mode, go to Options > enable Piston Settings.
You should be able to double click ‘settings’
