My piston worked perfectly when I was using only one garage gate sensor. When I added second it gives me 2 wrong notifications at the same time.
Sometimes my garage gate opens by itself after a second it was closed. I created a piston which checks if this situation happened and gives me a notification. Everything worked great until I added second gate sensor as a trigger. Now I get 2 notifications at same time after every garage gate closing.
See above
16.10.2024, 16:55:46 +395ms
+3ms ╔Working queued event [Czujnik bramy garażowej 2].contact = closed with a delay of 621ms, canQueue: false, calledMyself: true
+8ms ║RunTime initialize > 7 LockT > 0ms > r9T > 3ms > pistonT > 1ms (first state access 1 m:4 3 4)
+14ms ║Runtime (6844 bytes) initialized in 3ms (v0.3.114.20231008_HE)
+16ms ║╔Execution stage started
+193ms ║║Found matching value, duration 1031ms for is < 3000ms threshold = true
+194ms ║║Comparison (enum) closed was (string) closed = true (170ms)
+196ms ║║Condition #2 evaluated true (175ms)
+197ms ║║Condition group #1 evaluated true (condition did not change) (177ms)
+216ms ║║Executed device command [Paulina].deviceNotification(Brama garażowa sama się otworzyła!) (15ms)
+233ms ║║Executed device command [Seba].deviceNotification(Brama garażowa sama się otworzyła!) (14ms)
+240ms ║║Comparison (enum) off is (string) on = false (1ms)
+242ms ║║Condition #6 evaluated false (6ms)
+243ms ║║Condition group #5 evaluated false (condition did not change) (7ms)
+248ms ║╚Execution stage complete. (232ms)
+252ms ╚Event processed successfully (251ms)
16.10.2024, 16:55:45 +593ms
+3ms ╔Received event [Czujnik bramy garażowej].contact = closed with a delay of 39ms, canQueue: true, calledMyself: false
+32ms ║RunTime initialize > 31 LockT > 1ms > r9T > 3ms > pistonT > 1ms (first state access 24 m:27 4 27)
+38ms ║Runtime (6880 bytes) initialized in 3ms (v0.3.114.20231008_HE)
+40ms ║╔Execution stage started
+303ms ║║No matching value, duration 0ms for is < 3000ms threshold = false
+304ms ║║Comparison (enum) closed was (string) closed = false (244ms)
+496ms ║║Found matching value, duration 298ms for is < 3000ms threshold = true
+497ms ║║Comparison (enum) open was (string) closed = true (191ms)
+523ms ║║Condition #2 evaluated true (456ms)
+526ms ║║Condition group #1 evaluated true (condition changed) (482ms)
+701ms ║║Executed device command [Paulina].deviceNotification(Brama garażowa sama się otworzyła!) (170ms)
+740ms ║║Executed device command [Seba].deviceNotification(Brama garażowa sama się otworzyła!) (37ms)
+748ms ║║Comparison (enum) off is (string) on = false (2ms)
+751ms ║║Condition #6 evaluated false (6ms)
+753ms ║║Condition group #5 evaluated false (condition did not change) (10ms)
+759ms ║╚Execution stage complete. (719ms)
+765ms ╚Event processed successfully (763ms)
16.10.2024, 16:55:45 +855ms
+4ms ╔Received event [Czujnik bramy garażowej 2].contact = closed with a delay of 81ms, canQueue: true, calledMyself: false
+18ms ╚Event queued (15ms)
16.10.2024, 16:55:19 +198ms
+3ms ╔Working queued event [Czujnik bramy garażowej].contact = open with a delay of 852ms, canQueue: false, calledMyself: true
+8ms ║RunTime initialize > 7 LockT > 0ms > r9T > 3ms > pistonT > 0ms (first state access 0 m:4 3 4)
+14ms ║Runtime (6835 bytes) initialized in 3ms (v0.3.114.20231008_HE)
+15ms ║╔Execution stage started
+114ms ║║Found matching value, duration 1494564ms for is < 3000ms threshold = false
+116ms ║║Comparison (enum) open was (string) closed = false (91ms)
+240ms ║║No matching value, duration 0ms for is < 3000ms threshold = false
+241ms ║║Comparison (enum) open was (string) closed = false (125ms)
+243ms ║║Condition #2 evaluated false (222ms)
+245ms ║║Condition group #1 evaluated false (condition did not change) (225ms)
+248ms ║╚Execution stage complete. (233ms)
+253ms ╚Event processed successfully (251ms)
16.10.2024, 16:55:18 +459ms
