set hue apparently stopped working on 2 monoprice (Aeotec v1) RGB bulbs.
I don’t think this was due to modification of the script. Bulbs should be set to random hue during day, blue at night.
Bulbs are always blue. After manually changing to another color, colors will reset at night back to blue and stay blue. So apparently Set Color is working, Set Hue is not. I noticed a math error in the log. Not sure if that is new.
Web Core log
|+2ms|╔Received event [Foyer Multi Sensor].motion = inactive with a delay of 160ms|
|+133ms|║RunTime Analysis CS > 21ms > PS > 69ms > PE > 43ms > CE|
|+136ms|║Runtime (46262 bytes) successfully initialized in 69ms (v0.3.107.20180806) (133ms)|
|+138ms|║╔Execution stage started|
|+155ms|║║Comparison (enum) inactive changes_to (string) active = false (1ms)|
|+157ms|║║Cancelling condition #2's schedules...|
|+158ms|║║Condition #2 evaluated false (14ms)|
|+160ms|║║Cancelling condition #1's schedules...|
|+161ms|║║Condition group #1 evaluated false (state changed) (17ms)|
|+165ms|║║Cancelling statement #4's schedules...|
|+289ms|║║Executed physical command [Stair RGBW Light 1].off() (119ms)|
|+290ms|║║Executed [Stair RGBW Light 1].off (121ms)|
|+313ms|║║Executed physical command [Stair RGBW Light 2].off() (18ms)|
|+314ms|║║Executed [Stair RGBW Light 2].off (22ms)|
|+317ms|║╚Execution stage complete. (180ms)|
|+319ms|╚Event processed successfully (319ms)|
|12/11/2018, 7:20:06 PM +417ms|
|+2ms|╔Received event [Foyer Multi Sensor].motion = active with a delay of 202ms|
|+137ms|║RunTime Analysis CS > 23ms > PS > 75ms > PE > 39ms > CE|
|+139ms|║Runtime (46230 bytes) successfully initialized in 75ms (v0.3.107.20180806) (137ms)|
|+141ms|║╔Execution stage started|
|+157ms|║║Comparison (enum) active changes_to (string) active = true (1ms)|
|+160ms|║║Cancelling condition #2's schedules...|
|+161ms|║║Condition #2 evaluated true (13ms)|
|+162ms|║║Cancelling condition #1's schedules...|
|+163ms|║║Condition group #1 evaluated true (state changed) (17ms)|
|+172ms|║║Comparison (integer) 1 is_equal_to (integer) 0 = false (2ms)|
|+174ms|║║Cancelling condition #48's schedules...|
|+175ms|║║Condition #48 evaluated false (9ms)|
|+176ms|║║Cancelling condition #37's schedules...|
|+177ms|║║Condition group #37 evaluated false (state changed) (11ms)|
|+181ms|║║Cancelling statement #38's schedules...|
|+207ms|║║Calculating (integer) 1 * (integer) 10 >> (integer) 10|
|+212ms|║║Calculating (integer) 60 + (integer) 10 >> (integer) 70|
|+224ms|║║Calculating (string) At + (string) 19:20 >> (string) At 19:20|
|+231ms|║║Calculating (string) At 19:20 + (string) ... sunlightScale0to4: >> (string) At 19:20... sunlightScale0to4:|
|+238ms|║║Calculating (string) At 19:20... sunlightScale0to4: + (string) 1 >> (string) At 19:20... sunlightScale0to4: 1|
|+245ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1 + (string) ... Setting to random hues >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues|
|+250ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1... Setting to random hues + (string) 115 >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115|
|+256ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 + (string) and >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and|
|+261ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and + (string) 326 >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326|
|+266ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326 + (string) at >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326 at|
|+271ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326 at + (string) 70 >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326 at 70|
|+275ms|║║Calculating (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326 at 70 + (string) % >> (string) At 19:20... sunlightScale0to4: 1... Setting to random hues 115 and 326 at 70%|
|+280ms|║║Executed virtual command [Stair RGBW Light 1].setState (1ms)|
|+320ms|║║Executed physical command [Stair RGBW Light 1].setHue([80]) (31ms)|
|+321ms|║║Executed [Stair RGBW Light 1].setHue (34ms)|
|+331ms|║║Calculating (integer) 1 * (integer) 10 >> (integer) 10|
|+337ms|║║Calculating (integer) 60 + (integer) 10 >> (integer) 70|
|+370ms|║║Executed physical command [Stair RGBW Light 1].setLevel([70]) (28ms)|
|+371ms|║║Executed [Stair RGBW Light 1].setLevel (31ms)|
|+375ms|║║Cancelling statement #41's schedules...|
|+406ms|║║Executed physical command [Stair RGBW Light 2].setHue([1]) (20ms)|
|+407ms|║║Executed [Stair RGBW Light 2].setHue (23ms)|
|+416ms|║║Calculating (integer) 1 * (integer) 10 >> (integer) 10|
|+421ms|║║Calculating (integer) 60 + (integer) 10 >> (integer) 70|
|+445ms|║║Executed physical command [Stair RGBW Light 2].setLevel([70]) (20ms)|
|+447ms|║║Executed [Stair RGBW Light 2].setLevel (23ms)|
|+451ms|║╚Execution stage complete. (311ms)|
|+452ms|╚Event processed successfully (452ms)|
IDE Log
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:23 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
Possible solutions: round(float), round(double), find(), rint(double), find(groovy.lang.Closure), random() @line 303 (huesatToRGB)
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:23 PM: debug setColor([hue:77])
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:23 PM: debug setHue(77)
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:19 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:19 PM: debug setColor([hue:75])
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:19 PM: debug setHue(75)
[0800a5cc-ed9a-49d2-84ee-43a0fb6ea934](https://graph-na04-useast2.api.smartthings.com/ide/logs#0800a5cc-ed9a-49d2-84ee-43a0fb6ea934) 7:28:16 PM: debug Parse returned [Kitchen table is on, Kitchen table dimmed 35 %]
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:13 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:13 PM: debug setColor([hue:72])
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:13 PM: debug setHue(72)
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/8', [name:hue, value:0, descriptionText:Color has changed, displayed:false])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/7', [name:level, value:1, descriptionText:Level has changed to 1%])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/6', [name:colorTemperature, value:2890, descriptionText:Color temperature has changed])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/4', [name:switch, value:on])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/3', [name:saturation, value:0, descriptionText:Color has changed, displayed:false])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/3', [name:colorTemperature, value:2890, descriptionText:Color temperature has changed])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/4', [name:hue, value:100, descriptionText:Color has changed, displayed:false])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/4', [name:level, value:100, descriptionText:Level has changed to 100%])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/2', [name:hue, value:0, descriptionText:Color has changed, displayed:false])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/3', [name:color, value:#FFD381, descriptionText:Color has changed, displayed:true])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/2', [name:colorTemperature, value:2890, descriptionText:Color temperature has changed])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/3', [name:hue, value:0, descriptionText:Color has changed, displayed:false])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/2', [name:level, value:100, descriptionText:Level has changed to 100%])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug super_connect 9 may not reachable by Hue bridge
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/1', [name:hue, value:23, descriptionText:Color has changed, displayed:false])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug super_connect 8 may not reachable by Hue bridge
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/1', [name:colorTemperature, value:2710, descriptionText:Color temperature has changed])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug super_connect 5 may not reachable by Hue bridge
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug createChildDeviceEvent('00178824FA82/1', [name:switch, value:on])
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug super_connect 4 may not reachable by Hue bridge
[b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8](https://graph-na04-useast2.api.smartthings.com/ide/logs#b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8) 7:28:08 PM: debug 'zw device: 10, command: 2603, payload: 46 ' parsed to [[name:switch, value:on, descriptionText:Stair RGBW Light 2 was turned on, isStateChange:false, displayed:false, linkText:Stair RGBW Light 2], [name:level, value:70, unit:%, isStateChange:false, displayed:false, linkText:Stair RGBW Light 2, descriptionText:Stair RGBW Light 2 level is 70%]]
[a52d0977-f255-4308-aded-3ccb38b584fc](https://graph-na04-useast2.api.smartthings.com/ide/logs#a52d0977-f255-4308-aded-3ccb38b584fc) 7:28:08 PM: debug 'zw device: 0F, command: 2603, payload: 46 ' parsed to [[name:switch, value:on, descriptionText:Stair RGBW Light 1 was turned on, isStateChange:false, displayed:false, linkText:Stair RGBW Light 1], [name:level, value:70, unit:%, isStateChange:false, displayed:false, linkText:Stair RGBW Light 1, descriptionText:Stair RGBW Light 1 level is 70%]]
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:08 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:08 PM: debug setColor([hue:69])
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:08 PM: debug setHue(69)
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug checkBridgeStatus()
[e51419d3-b76b-4865-88cf-ca0042d7f179](https://graph-na04-useast2.api.smartthings.com/ide/logs#e51419d3-b76b-4865-88cf-ca0042d7f179) 7:28:08 PM: debug poll()
[b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8](https://graph-na04-useast2.api.smartthings.com/ide/logs#b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8) 7:28:07 PM: debug 'zw device: 10, command: 2003, payload: 46 ' parsed to [[name:switch, value:on, descriptionText:Stair RGBW Light 2 was turned on, isStateChange:true, displayed:true, linkText:Stair RGBW Light 2], [name:level, value:70, unit:%, isStateChange:false, displayed:false, linkText:Stair RGBW Light 2, descriptionText:Stair RGBW Light 2 level is 70%]]
[a52d0977-f255-4308-aded-3ccb38b584fc](https://graph-na04-useast2.api.smartthings.com/ide/logs#a52d0977-f255-4308-aded-3ccb38b584fc) 7:28:07 PM: debug 'zw device: 0F, command: 2003, payload: 46 ' parsed to [[name:switch, value:on, descriptionText:Stair RGBW Light 1 was turned on, isStateChange:true, displayed:true, linkText:Stair RGBW Light 1], [name:level, value:70, unit:%, isStateChange:false, displayed:false, linkText:Stair RGBW Light 1, descriptionText:Stair RGBW Light 1 level is 70%]]
[b5044580-ef9a-4cad-b338-ddc130b7ba84](https://graph-na04-useast2.api.smartthings.com/ide/logs#b5044580-ef9a-4cad-b338-ddc130b7ba84) 7:28:07 PM: info ║ At 19:28: Motion from Foyer Multi Sensor... Evening Light switch was already ON.
[b5044580-ef9a-4cad-b338-ddc130b7ba84](https://graph-na04-useast2.api.smartthings.com/ide/logs#b5044580-ef9a-4cad-b338-ddc130b7ba84) 7:28:06 PM: info ║ At 19:28: Motion from Foyer Multi Sensor... Running Light switch was already ON.
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:07 PM: debug ║║ Calculating (integer) 1 * (integer) 10 >> (integer) 10
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (string) At 19:28... sunlightScale0to4: + (string) 1 >> (string) At 19:28... sunlightScale0to4: 1
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (string) At 19:28... sunlightScale0to4: 1... Setting to random hues 134 and 268 + (string) at >> (string) At 19:28... sunlightScale0to4: 1... Setting to random hues 134 and 268 at
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (string) At + (string) 19:28 >> (string) At 19:28
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (integer) 1 * (integer) 10 >> (integer) 10
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (string) At 19:28... sunlightScale0to4: 1... Setting to random hues + (string) 134 >> (string) At 19:28... sunlightScale0to4: 1... Setting to random hues 134
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (string) At 19:28... sunlightScale0to4: 1 + (string) ... Setting to random hues >> (string) At 19:28... sunlightScale0to4: 1... Setting to random hues
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Cancelling statement #38's schedules...
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (string) At 19:28 + (string) ... sunlightScale0to4: >> (string) At 19:28... sunlightScale0to4:
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Comparison (integer) 1 is_equal_to (integer) 0 = false (2ms)
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Calculating (integer) 60 + (integer) 10 >> (integer) 70
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Cancelling condition #1's schedules...
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Condition #48 evaluated false (7ms)
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Condition group #37 evaluated false (state did not change) (9ms)
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Condition group #1 evaluated true (state changed) (18ms)
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║║ Cancelling condition #2's schedules...
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: trace ║╚ Execution stage started
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: trace ║ Runtime (46233 bytes) successfully initialized in 73ms (v0.3.107.20180806) (221ms)
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: debug ║ RunTime Analysis CS > 100ms > PS > 73ms > PE > 48ms > CE
[5088c6f2-947d-472c-a886-ce1d2bf0fd70](https://graph-na04-useast2.api.smartthings.com/ide/logs#5088c6f2-947d-472c-a886-ce1d2bf0fd70) 7:28:06 PM: info ╚ Received event [Foyer Multi Sensor].motion = active with a delay of 218ms
[b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8](https://graph-na04-useast2.api.smartthings.com/ide/logs#b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8) 7:28:07 PM: debug setLevel(70, 1)
[b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8](https://graph-na04-useast2.api.smartthings.com/ide/logs#b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8) 7:28:07 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
[b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8](https://graph-na04-useast2.api.smartthings.com/ide/logs#b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8) 7:28:07 PM: debug setColor([hue:81])
[b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8](https://graph-na04-useast2.api.smartthings.com/ide/logs#b7c2d1d8-ad77-4264-b28f-7e4ee4d58cd8) 7:28:07 PM: debug setHue(81)
[a52d0977-f255-4308-aded-3ccb38b584fc](https://graph-na04-useast2.api.smartthings.com/ide/logs#a52d0977-f255-4308-aded-3ccb38b584fc) 7:28:06 PM: debug setLevel(70, 1)
[a52d0977-f255-4308-aded-3ccb38b584fc](https://graph-na04-useast2.api.smartthings.com/ide/logs#a52d0977-f255-4308-aded-3ccb38b584fc) 7:28:06 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
[a52d0977-f255-4308-aded-3ccb38b584fc](https://graph-na04-useast2.api.smartthings.com/ide/logs#a52d0977-f255-4308-aded-3ccb38b584fc) 7:28:06 PM: debug setColor([hue:98])
[a52d0977-f255-4308-aded-3ccb38b584fc](https://graph-na04-useast2.api.smartthings.com/ide/logs#a52d0977-f255-4308-aded-3ccb38b584fc) 7:28:06 PM: debug setHue(98)
[d8f19a43-0297-48b7-9af9-84344099e29d](https://graph-na04-useast2.api.smartthings.com/ide/logs#d8f19a43-0297-48b7-9af9-84344099e29d) 7:28:06 PM: info SHM isActiveSensor(motion:active, app: off, location: off) = false, locationId: 5613fe92-2062-4e2c-92de-2152da1e4f1e, ISA: d8f19a43-0297-48b7-9af9-84344099e29d
[d8f19a43-0297-48b7-9af9-84344099e29d](https://graph-na04-useast2.api.smartthings.com/ide/logs#d8f19a43-0297-48b7-9af9-84344099e29d) 7:28:06 PM: debug motionOrContactHandler(Foyer Multi Sensor motion:active)
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:04 PM: error groovy.lang.MissingMethodException: No signature of method: static java.lang.Math.round() is applicable for argument types: (null) values: [null]
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:04 PM: debug setColor([hue:66])
[a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa](https://graph-na04-useast2.api.smartthings.com/ide/logs#a7a41e7a-e1d0-4b31-849f-8fdd7c41a8aa) 7:28:04 PM: debug setHue(66)
[b5044580-ef9a-4cad-b338-ddc130b7ba84](https://graph-na04-useast2.api.smartthings.com/ide/logs#b5044580-ef9a-4cad-b338-ddc130b7ba84) 7:28:03 PM: info ║ At 19:28: Motion from Kitchen GE Motion... Evening Light switch was already ON.
[b5044580-ef9a-4cad-b338-ddc130b7ba84](https://graph-na04-useast2.api.smartthings.com/ide/logs#b5044580-ef9a-4cad-b338-ddc130b7ba84) 7:28:03 PM: info ║ At 19:28: Motion from Kitchen GE Motion... Running Light switch was already ON.
[d8f19a43-0297-48b7-9af9-84344099e29d](https://graph-na04-useast2.api.smartthings.com/ide/logs#d8f19a43-0297-48b7-9af9-84344099e29d) 7:28:03 PM: info SHM isActiveSensor(motion:active, app: off, location: off) = false, locationId: 5613fe92-2062-4e2c-92de-2152da1e4f1e, ISA: d8f19a43-0297-48b7-9af9-84344099e29d
[d8f19a43-0297-48b7-9af9-84344099e29d](https://graph-na04-useast2.api.smartthings.com/ide/logs#d8f19a43-0297-48b7-9af9-84344099e29d) 7:28:03 PM: debug motionOrContactHandler(Hall Motion Sensor motion:active)
[b5044580-ef9a-4cad-b338-ddc130b7ba84](https://graph-na04-useast2.api.smartthings.com/ide/logs#b5044580-ef9a-4cad-b338-ddc130b7ba84) 7:28:04 PM: info ║ At 19:28: Motion from Hall Motion Sensor... Evening Light switch was already ON.
[b5044580-ef9a-4cad-b338-ddc130b7ba84](https://graph-na04-useast2.api.smartthings.com/ide/logs#b5044580-ef9a-4cad-b338-ddc130b7ba84) 7:28:03 PM: info ║ At 19:28: Motion from Hall Motion Sensor... Running Light switch was already ON.
[4a162a2e-04df-4282-ae12-8b787cb24e36](https://graph-na04-useast2.api.smartthings.com/ide/logs#4a162a2e-04df-4282-ae12-8b787cb24e36) 7:28:03 PM: debug Non-parsed event: zw device: 08, command: 600D, payload: 02 00 82 01
