porch light is not changing to white upon RING motion detection, and not changing back to blue after no motion detected.
When RING doorbell motion is changes to active, set the porch light to 100% and set color to soft white, until RING doorbell has been inactive for approx 3 minutes, then change back to global variable color (in this case, blue)
see item 2. I’m new to the “repeat do until” loop, so sure I’m doing this all wrong.
11/9/2020, 7:33:24 PM +175ms![turn%20on%20the%20porch%20light|447x499]
+0ms ╔Received event [Home].time = 1604972005914 with a delay of -1740ms
+107ms ║RunTime Analysis CS > 24ms > PS > 45ms > PE > 39ms > CE
+110ms ║Runtime (46076 bytes) successfully initialized in 45ms (v0.3.110.20191009) (109ms)
+111ms ║╔Execution stage started
+112ms ║╚Execution stage complete. (1ms)
+113ms ╚Event processed successfully (114ms)
11/9/2020, 7:31:05 PM +182ms
+1ms ╔Received event [Ring Doorbell].motion = inactive with a delay of 76ms
+122ms ║RunTime Analysis CS > 18ms > PS > 59ms > PE > 45ms > CE
+124ms ║Runtime (46072 bytes) successfully initialized in 59ms (v0.3.110.20191009) (122ms)
+134ms ║║Comparison (boolean) false is (boolean) false = true (1ms)
+136ms ║║Condition #49 evaluated true (6ms)
+144ms ║║Comparison (enum) on is (string) on = true (1ms)
+146ms ║║Condition #80 evaluated true (9ms)
+149ms ║║Comparison (enum) inactive changes_to (string) active = false (0ms)
+151ms ║║Cancelling condition #2’s schedules…
+152ms ║║Condition #2 evaluated false (6ms)
+153ms ║║Cancelling condition #1’s schedules…
+154ms ║║Condition group #1 evaluated false (state changed) (24ms)
+161ms ║║Comparison (boolean) false is (boolean) true = false (1ms)
+163ms ║║Condition #71 evaluated false (6ms)
+163ms ║║Condition group #68 evaluated false (state did not change) (7ms)
+166ms ║╚Execution stage complete. (41ms)
+167ms ╚Event processed successfully (167ms)
11/9/2020, 7:30:25 PM +719ms
+1ms ╔Received event [Ring Doorbell].motion = active with a delay of 69ms
+114ms ║RunTime Analysis CS > 18ms > PS > 55ms > PE > 40ms > CE
+117ms ║Runtime (46077 bytes) successfully initialized in 55ms (v0.3.110.20191009) (114ms)
+126ms ║║Comparison (boolean) false is (boolean) false = true (1ms)
+128ms ║║Condition #49 evaluated true (6ms)
+138ms ║║Comparison (enum) on is (string) on = true (1ms)
+139ms ║║Condition #80 evaluated true (10ms)
+143ms ║║Comparison (enum) active changes_to (string) active = true (1ms)
+144ms ║║Cancelling condition #2’s schedules…
+145ms ║║Condition #2 evaluated true (5ms)
+155ms ║║Comparison (enum) off is (string) off = true (1ms)
+156ms ║║Condition #48 evaluated true (10ms)
+157ms ║║Cancelling condition #1’s schedules…
+158ms ║║Condition group #1 evaluated true (state changed) (37ms)
+160ms ║║Cancelling statement #26’s schedules…
+173ms ║║Executed physical command [Front Porch sengled].setColorTemperature([2700]) (9ms)
+174ms ║║Executed [Front Porch sengled].setColorTemperature (10ms)
+186ms ║║Skipped execution of physical command [Front Porch sengled].setLevel([100]) because it would make no change to the device. (8ms)
+187ms ║║Executed [Front Porch sengled].setLevel (9ms)
+190ms ║║Cancelling statement #64’s schedules…
+193ms ║║Executed virtual command wait (0ms)
+195ms ║║Requesting a wake up for Mon, Nov 9 2020 @ 7:33:25 PM CST (in 180.0s)
+200ms ║╚Execution stage complete. (82ms)
+201ms ║Setting up scheduled job for Mon, Nov 9 2020 @ 7:33:25 PM CST (in 179.995s)
+207ms ╚Event processed successfully (207ms)
