I try to run a routine, that turns off a bunch of lights and dims one to 5%, but it throws up an error message while executing the routine
Lights go off and a single light dims to 5%
Routine is stopped from executing
28.11.2021 13.14.24 +978ms
+0ms ╔Received event [Home].mode = Netflix with a delay of 49ms
+65ms ║RunTime Analysis CS > 14ms > PS > 11ms > PE > 39ms > CE
+67ms ║Runtime (40385 bytes) successfully initialized in 11ms (v0.3.113.20210203) (66ms)
+76ms ║║Comparison (string) :3850b17977192f27c04bfe3eade36b57: changes_to (string) :3850b17977192f27c04bfe3eade36b57: = true (0ms)
+77ms ║║Cancelling condition #8's schedules...
+78ms ║║Condition #8 evaluated true (5ms)
+80ms ║║Cancelling condition #7's schedules...
+81ms ║║Condition group #7 evaluated true (state changed) (8ms)
+83ms ║║Cancelling statement #9's schedules...
+94ms ║║Executed physical command [Reol Lampe].off() (6ms)
+96ms ║║Executed [Reol Lampe].off (8ms)
+102ms ║║Skipped execution of physical command [Reol Lampe 2].off([]) because it would make no change to the device. (3ms)
+103ms ║║Executed [Reol Lampe 2].off (5ms)
+130ms ║║Skipped execution of physical command [Rund Lampe].off([]) because it would make no change to the device. (24ms)
+131ms ║║Executed [Rund Lampe].off (26ms)
+140ms ║║Executed physical command [Stuen - Lille lampe (ny)].off() (6ms)
+141ms ║║Executed [Stuen - Lille lampe (ny)].off (8ms)
+149ms ║║Executed physical command [Stuen - Standerlampe 1].off() (5ms)
+150ms ║║Executed [Stuen - Standerlampe 1].off (7ms)
+159ms ║║Executed physical command [Stuen Loftslampe].off() (6ms)
+160ms ║║Executed [Stuen Loftslampe].off (8ms)
+166ms ║║Skipped execution of physical command [Udestuen].off([]) because it would make no change to the device. (4ms)
+167ms ║║Executed [Udestuen].off (6ms)
+169ms ║║Cancelling statement #11's schedules...
+180ms ║║Executed physical command [Standerlampe 2].setLevel([5]) (7ms)
+181ms ║║Executed [Standerlampe 2].setLevel (8ms)
+183ms ║║Cancelling statement #13's schedules...
+648ms ║║Skipped execution of physical command [Køkken Lille Lampe 1 Bridge].off([]) because it would make no change to the device. (4ms)
+649ms ║║Executed [Køkken Lille Lampe 1 Bridge].off (6ms)
+655ms ║║Skipped execution of physical command [Køkken Lille Lampe 2].off([]) because it would make no change to the device. (4ms)
+656ms ║║Executed [Køkken Lille Lampe 2].off (6ms)
+657ms ║║An error occurred while executing the event: java.lang.NullPointerException: Cannot invoke method hasCommand() on null object
+659ms ║╚Execution stage complete. (591ms)
+660ms ╚Event processed successfully (660ms)
