I wrote an example piston to try to understand how scheduling works. I thought I understood, but clearly I do not.
The piston is set up to initialize only once (by manually running it) … it then attempts to set up 6 timers each one minute apart (with an offset of 30 seconds) …
I thought I would see 6 timers being set, but in fact only one timer is scheduled and it is for the furthest out timer, not the next timer.
Only the last furthest out timer (+6 minutes) is scheduled.
