Not a problem, trying to design a piston
I want webcore to check every ten minutes for any locks unlocked or contacts open and if there are, send a push notification of which locks are unlocked and which contacts are open. If all locks are locked and all contacts are closed, I don’t want a notification. If there are locks unlocked and all contacts are closed, I just want notified of the locks unlocked and so forth.
I just have no idea how to set it up. Currently I have two pistons that do this, one piston to check the locks and notify and another piston to check the contacts and notify. I want to do it inside of one piston so I only get one notification every ten minutes.
Thank you for your help
