The piston is taking an excessive amount of time to execute - up to 10 minutes. I might have missed it, but the lights did not appear to flash at all when they should have been triggered either.
This piston is to optimize the use of my whole house fan(s). I’d like to be notified when the temperature outside has dropped below the temperature inside by a flashing light in my kitchen and bedroom. Then, when I open one of the designated windows, the thermostat should switch to “off”, and the whole house fans switch to “on”. Conversely, once the temperature outside has risen past the indoor temperature, I’d like the lights to flash again. Once all the windows are closed the thermostat should turn to “auto”, and the whole house fans turn to “off”.
The fans and thermostat seem to work, but even though it is cooler outside by a couple degrees at the time I open the windows, it still takes ~10 minutes for the fans to kick on and the thermostat to switch. The delay is also present when I close the windows once the fans are running. Neither my wife or I noticed the lights flash at all (though not impossible that we were in different rooms at the time), but my ST app did report that the commands were sent.
I had logs turned off… Sorry about that.
