This isn’t directly related to Webcore but I prefer to talk to you all about it knowing that Webcore will be the function for what I’m trying to do.
Recently, I wired a GE Z-wave switch so that the switch always has power and the light fixture it was connected to would always have power too. I then put some Sylvania bulbs in the fixtures and just use the switch as a trigger for a Webcore piston that turns on/off the bulbs and a bunch of other things depending on conditions. I’m curious if the same would work for a dimmer switch?
I understand that traditional and z-wave dimmer switches dim the bulbs they are connected to by constraining the voltage that gets to the bulb. But, would a dimmer switch with just the hot wired to it work as a dimmer if I use a piston to replicate the state of the switch into selected bulbs? I know it can be done in Webcore as I’ve done it with numerous virtual dimmer switches but now I want a physical switch as well.
Thanks as always for all your help!
