I have one piston that will set global variables (one after another) to boolean values. In another piston I use “wait for X to change to true”. The problem is that all the hardware actions that are tied to the global variables are in the same piston so I’m not sure if what I’m trying to do is possible? I have enabled parallelism and Async IF.
The expected behavior is that the hardware actions should fire but it doesn’t seem to be the case.
(PUT YOUR INFO HERE)
