Hello i’m in the same situation of this topic Sending POST with JSON array and I had seen that the solution proposed and confirmerd was using an IFTTT Post for pass a correct Json string to web-cast service, because i cannot insert the square char “[” and “]” at the begin and at the end in a webcore code using a Post Request.
Code present this:
Make a POST request to http://<ip>:<port> with JSON encoded data
{“mediaTitle”:“TEXT”,“mediaSubTitle”:“TEXT”…}
I want this:
[{“mediaTitle”:“TEXT”,“mediaSubTitle”:“TEXT”…}]
In the linked post there isn’t the solution in detail and I ask you some details to pass a Json correct string using webcore and IFTTT.
Thz to all.
