I have a smarrthings water sensor, and I want to use it to trigger an Alexa routine, like make an announcement and send Alexa notification.
It seems like the only solution is to use Webcore and create a piston that activates when the water sensor detects water, which could then be used to trigger a “simulated motion sensor” in smartthings, which could then be detected by Alexa as a motion trigger event.
Can’t get it to work, but I’m a total novice and don’t really know how to do it.
