I would like to create a piston to execute routines without using virtual switches to do so. So far I have not been able to accomplish this. Is there a way to achieve this using Webhooks? I use google home/assistant commands to turn off and on switches that execute a routine if they are turned on. Is there a way to use webhooks to connect google assistant directly to core?
Using Webhooks/IFTTT/webCoRE to execute routine
whoismoses
I don’t believe so, not easily at lease.
Any reason you don’t want to use virtual switches and momentary buttons? I lost trust in ST Routines and migrated them all to momentary buttons. They work all the time can be called…
by Google / Alexa
by the ST app
by Pistons
