I am running this piston when we are away from the house.(vacation & late nights)
Problem I am having is if the lights are on when the piston ends the lights stay on. What do I need to do to turn the lights off.
Mike
Vacation Lighting Help
siam
c1arkbar
At the bottom of the piston add a new condition. Time happens at daily 10:31 pm and (whatever you Monitor to know you are away is true) then turn off the lights.
freddyq
@siam I’ve been thinking of putting together a similar piston…can I just check that this one randomly toggles all the lights selected? So that if the random toggle for all of them ends up being ‘on’ in one particular cycle, they could all be turned on? And similarly all turned off?
siam
freddyq
Do whatever you would like with it. I got it off the board a while ago just added my devices. If you make changes & add an all off at the end please post it.
Mike
