I have piston that is designed to turn on my outside lights at sunset. It will change the colors of those lights based on the date (Christmas time is red/green/blue/etc, Fourth of July is red/white/blue, etc). On all other “undefined” days, the lights turn on set to the default value “Warm White”.
On dates that are not defined, the lights turn on and are set to the default color “Warm White”.
On dates that are not defined, the lights are turning on and are set to the color “White” (not “Warm White”). This is a harsh 5000k or so, and is unpleasing to the eye.
1/7/2021, 9:59:59 PM +76ms
+0ms ╔Received event [Home].time = 1610078400000 with a delay of -925ms
+93ms ║RunTime Analysis CS > 18ms > PS > 6ms > PE > 70ms > CE
+96ms ║Runtime (53485 bytes) successfully initialized in 6ms (v0.3.110.20191009) (95ms)
+105ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609999200000, d:2, vt:string]]]
+110ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+116ms ║║Comparison (date) 1609999200000 is (date) 1618981200000 = false (4ms)
+121ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+127ms ║║Comparison (date) 1609999200000 is (date) 1625374800000 = false (2ms)
+134ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+139ms ║║Comparison (date) 1609999200000 is (date) 1627448400000 = false (2ms)
+144ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+149ms ║║Comparison (date) 1609999200000 is (date) 1635138000000 = false (2ms)
+154ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+159ms ║║Comparison (date) 1609999200000 is (date) 1635656400000 = false (3ms)
+164ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+171ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+176ms ║║Comparison (date) 1609999200000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (3ms)
+182ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+187ms ║║Comparison (date) 1609999200000 is (date) 1613282400000 = false (2ms)
+192ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+197ms ║║Comparison (date) 1609999200000 is (date) 1617166800000 = false (2ms)
+202ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+207ms ║║Comparison (date) 1609999200000 is (date) 1609912800000 = false (2ms)
+209ms ║║Cancelling statement #18’s schedules…
+214ms ║║Executed virtual command setVariable (3ms)
+219ms ║║Executed virtual command setVariable (3ms)
+225ms ║║Executed virtual command setVariable (2ms)
+230ms ║║Executed virtual command setVariable (3ms)
+235ms ║║Executed virtual command setVariable (2ms)
+241ms ║║Executed virtual command setVariable (3ms)
+334ms ║║Comparison (time) 79199321 happens_daily_at (time) 1610059740000 = false (0ms)
+336ms ║║Cancelling condition #56’s schedules…
+337ms ║║Condition #56 evaluated false (91ms)
+338ms ║║Cancelling statement #56’s schedules…
+343ms ║║Requesting time schedule wake up at Fri, Jan 8 2021 @ 4:49:00 PM CST
+345ms ║║Cancelling condition #55’s schedules…
+346ms ║║Condition group #55 evaluated false (state changed) (101ms)
+351ms ║║Comparison (time) 79199425 happens_daily_at (time) 79200000 = true (1ms)
+352ms ║║Time restriction check passed
+354ms ║║Cancelling condition #79’s schedules…
+355ms ║║Condition #79 evaluated true (7ms)
+356ms ║║Cancelling statement #79’s schedules…
+360ms ║║Requesting time schedule wake up at Fri, Jan 8 2021 @ 10:00:00 PM CST
+363ms ║║Cancelling condition #78’s schedules…
+364ms ║║Condition group #78 evaluated true (state changed) (15ms)
+366ms ║║Cancelling statement #86’s schedules…
+10133ms ║║Executed physical command [Outside Light 01].setLevel([10]) (9761ms)
+10134ms ║║Executed [Outside Light 01].setLevel (9763ms)
+10156ms ║║Executed physical command [Outside Light 02].setLevel([10]) (20ms)
+10157ms ║║Executed [Outside Light 02].setLevel (21ms)
+10179ms ║║Executed physical command [Outside Light 03].setLevel([10]) (20ms)
+10180ms ║║Executed [Outside Light 03].setLevel (21ms)
+10202ms ║║Executed physical command [Outside Light 04].setLevel([10]) (19ms)
+10203ms ║║Executed [Outside Light 04].setLevel (21ms)
+10206ms ║║Cancelling statement #88’s schedules…
+10221ms ║║Executed physical command [Gardenspot mini RGB].setLevel([30]) (9ms)
+10222ms ║║Executed [Gardenspot mini RGB].setLevel (11ms)
+10228ms ║║Comparison (time) 79209302 happens_daily_at (time) 1610027580000 = false (0ms)
+10230ms ║║Condition #73 evaluated false (5ms)
+10232ms ║║Cancelling statement #73’s schedules…
+10237ms ║║Requesting time schedule wake up at Fri, Jan 8 2021 @ 7:53:00 AM CST
+10240ms ║║Condition group #72 evaluated false (state did not change) (14ms)
+10244ms ║╚Execution stage complete. (10147ms)
+10246ms ║Setting up scheduled job for Thu, Jan 7 2021 @ 11:30:00 PM CST (in 5390.678s), with 3 more jobs pending
+10252ms ╚Event processed successfully (10252ms)
1/7/2021, 4:48:59 PM +64ms
+1ms ╔Received event [Home].time = 1610059740000 with a delay of -936ms
+82ms ║RunTime Analysis CS > 23ms > PS > 4ms > PE > 54ms > CE
+85ms ║Runtime (53482 bytes) successfully initialized in 4ms (v0.3.110.20191009) (83ms)
+86ms ║╔Execution stage started
+93ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609999200000, d:2, vt:string]]]
+98ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+103ms ║║Comparison (date) 1609999200000 is (date) 1618981200000 = false (3ms)
+108ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+112ms ║║Comparison (date) 1609999200000 is (date) 1625374800000 = false (2ms)
+117ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+121ms ║║Comparison (date) 1609999200000 is (date) 1627448400000 = false (2ms)
+126ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+130ms ║║Comparison (date) 1609999200000 is (date) 1635138000000 = false (2ms)
+135ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+139ms ║║Comparison (date) 1609999200000 is (date) 1635656400000 = false (2ms)
+144ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+150ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+155ms ║║Comparison (date) 1609999200000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (3ms)
+160ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+165ms ║║Comparison (date) 1609999200000 is (date) 1613282400000 = false (2ms)
+169ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+174ms ║║Comparison (date) 1609999200000 is (date) 1617166800000 = false (2ms)
+178ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+183ms ║║Comparison (date) 1609999200000 is (date) 1609912800000 = false (2ms)
+185ms ║║Cancelling statement #18’s schedules…
+190ms ║║Executed virtual command setVariable (3ms)
+195ms ║║Executed virtual command setVariable (3ms)
+200ms ║║Executed virtual command setVariable (3ms)
+204ms ║║Executed virtual command setVariable (2ms)
+209ms ║║Executed virtual command setVariable (2ms)
+253ms ║║Comparison (time) 60539281 happens_daily_at (time) 1610059740000 = true (0ms)
+255ms ║║Time restriction check passed
+256ms ║║Cancelling condition #56’s schedules…
+257ms ║║Condition #56 evaluated true (39ms)
+258ms ║║Cancelling statement #56’s schedules…
+262ms ║║Requesting time schedule wake up at Fri, Jan 8 2021 @ 4:49:00 PM CST
+264ms ║║Cancelling condition #55’s schedules…
+265ms ║║Condition group #55 evaluated true (state changed) (48ms)
+267ms ║║Cancelling statement #57’s schedules…
+857ms ║║Executed physical command [Outside Light 01].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (586ms)
+858ms ║║Executed [Outside Light 01].setColor (588ms)
+877ms ║║Executed physical command [Outside Light 01].setLevel([100]) (16ms)
+878ms ║║Executed [Outside Light 01].setLevel (18ms)
+880ms ║║Cancelling statement #60’s schedules…
+904ms ║║Executed physical command [Outside Light 02].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (19ms)
+905ms ║║Executed [Outside Light 02].setColor (21ms)
+923ms ║║Executed physical command [Outside Light 02].setLevel([100]) (16ms)
+924ms ║║Executed [Outside Light 02].setLevel (17ms)
+926ms ║║Cancelling statement #63’s schedules…
+951ms ║║Executed physical command [Outside Light 03].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (21ms)
+952ms ║║Executed [Outside Light 03].setColor (22ms)
+970ms ║║Executed physical command [Outside Light 03].setLevel([100]) (15ms)
+972ms ║║Executed [Outside Light 03].setLevel (16ms)
+975ms ║║Cancelling statement #66’s schedules…
+1000ms ║║Executed physical command [Outside Light 04].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (20ms)
+1001ms ║║Executed [Outside Light 04].setColor (23ms)
+1020ms ║║Executed physical command [Outside Light 04].setLevel([100]) (15ms)
+1022ms ║║Executed [Outside Light 04].setLevel (18ms)
+1025ms ║║Cancelling statement #69’s schedules…
+1035ms ║║Executed physical command [Gardenspot mini RGB].setColor([[hex: #000000, hue:0, saturation:0, level:0]]) (4ms)
+1036ms ║║Executed [Gardenspot mini RGB].setColor (6ms)
+1046ms ║║Executed physical command [Gardenspot mini RGB].setLevel([100]) (7ms)
+1047ms ║║Executed [Gardenspot mini RGB].setLevel (8ms)
+1051ms ║║Cancelling statement #76’s schedules…
+1060ms ║║Skipped execution of physical command [Exterior Front].off([]) because it would make no change to the device. (4ms)
+1061ms ║║Executed virtual command [Exterior Front].setSwitch (6ms)
+1068ms ║║Comparison (time) 60540129 happens_daily_at (time) 1610027580000 = false (0ms)
+1070ms ║║Cancelling condition #73’s schedules…
+1071ms ║║Condition #73 evaluated false (7ms)
+1073ms ║║Cancelling statement #73’s schedules…
+1078ms ║║Requesting time schedule wake up at Fri, Jan 8 2021 @ 7:53:00 AM CST
+1081ms ║║Cancelling condition #72’s schedules…
+1082ms ║║Condition group #72 evaluated false (state changed) (18ms)
+1088ms ║╚Execution stage complete. (1002ms)
+1090ms ║Setting up scheduled job for Thu, Jan 7 2021 @ 10:00:00 PM CST (in 18659.846s), with 3 more jobs pending
+1102ms ╚Event processed successfully (1101ms)
1/7/2021, 7:52:59 AM +55ms
+0ms ╔Received event [Home].time = 1610027580000 with a delay of -945ms
+83ms ║RunTime Analysis CS > 22ms > PS > 4ms > PE > 57ms > CE
+86ms ║Runtime (53480 bytes) successfully initialized in 4ms (v0.3.110.20191009) (85ms)
+87ms ║╔Execution stage started
+95ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609999200000, d:2, vt:string]]]
+100ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+105ms ║║Comparison (date) 1609999200000 is (date) 1618981200000 = false (2ms)
+111ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+115ms ║║Comparison (date) 1609999200000 is (date) 1625374800000 = false (2ms)
+121ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+126ms ║║Comparison (date) 1609999200000 is (date) 1627448400000 = false (2ms)
+131ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+136ms ║║Comparison (date) 1609999200000 is (date) 1635138000000 = false (2ms)
+141ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+145ms ║║Comparison (date) 1609999200000 is (date) 1635656400000 = false (2ms)
+150ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+156ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+161ms ║║Comparison (date) 1609999200000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (3ms)
+166ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+171ms ║║Comparison (date) 1609999200000 is (date) 1613282400000 = false (2ms)
+175ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+180ms ║║Comparison (date) 1609999200000 is (date) 1617166800000 = false (2ms)
+185ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+189ms ║║Comparison (date) 1609999200000 is (date) 1609912800000 = false (2ms)
+191ms ║║Cancelling statement #18’s schedules…
+197ms ║║Executed virtual command setVariable (3ms)
+201ms ║║Executed virtual command setVariable (2ms)
+206ms ║║Executed virtual command setVariable (2ms)
+211ms ║║Executed virtual command setVariable (2ms)
+216ms ║║Executed virtual command setVariable (2ms)
+221ms ║║Executed virtual command setVariable (2ms)
+260ms ║║Comparison (time) 28379279 happens_daily_at (time) 1610059740000 = false (0ms)
+262ms ║║Condition #56 evaluated false (39ms)
+266ms ║║Cancelling statement #56’s schedules…
+270ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 4:49:00 PM CST
+272ms ║║Condition group #55 evaluated false (state did not change) (49ms)
+276ms ║║Comparison (time) 28379330 happens_daily_at (time) 79200000 = false (0ms)
+278ms ║║Condition #79 evaluated false (4ms)
+284ms ║║Cancelling statement #79’s schedules…
+287ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 10:00:00 PM CST
+289ms ║║Condition group #78 evaluated false (state did not change) (15ms)
+293ms ║║Comparison (time) 28379346 happens_daily_at (time) 84600000 = false (0ms)
+295ms ║║Condition #81 evaluated false (3ms)
+296ms ║║Cancelling statement #81’s schedules…
+299ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 11:30:00 PM CST
+301ms ║║Condition group #80 evaluated false (state did not change) (10ms)
+307ms ║║Comparison (time) 28379359 happens_daily_at (time) 1610027580000 = true (1ms)
+308ms ║║Time restriction check passed
+309ms ║║Cancelling condition #73’s schedules…
+310ms ║║Condition #73 evaluated true (6ms)
+311ms ║║Cancelling statement #73’s schedules…
+315ms ║║Requesting time schedule wake up at Fri, Jan 8 2021 @ 7:53:00 AM CST
+317ms ║║Cancelling condition #72’s schedules…
+318ms ║║Condition group #72 evaluated true (state changed) (14ms)
+320ms ║║Cancelling statement #74’s schedules…
+328ms ║║Skipped execution of physical command [Deck Lights].off([]) because it would make no change to the device. (4ms)
+329ms ║║Executed [Deck Lights].off (6ms)
+335ms ║║Skipped execution of physical command [Exterior Front].off([]) because it would make no change to the device. (4ms)
+336ms ║║Executed [Exterior Front].off (5ms)
+346ms ║║Executed physical command [Gardenspot mini RGB].off() (8ms)
+347ms ║║Executed [Gardenspot mini RGB].off (10ms)
+935ms ║║Executed physical command [Outside Light 01].off() (585ms)
+936ms ║║Executed [Outside Light 01].off (587ms)
+957ms ║║Executed physical command [Outside Light 02].off() (18ms)
+958ms ║║Executed [Outside Light 02].off (20ms)
+979ms ║║Executed physical command [Outside Light 03].off() (18ms)
+980ms ║║Executed [Outside Light 03].off (20ms)
+1006ms ║║Executed physical command [Outside Light 04].off() (23ms)
+1007ms ║║Executed [Outside Light 04].off (25ms)
+1012ms ║╚Execution stage complete. (925ms)
+1014ms ║Setting up scheduled job for Thu, Jan 7 2021 @ 4:49:00 PM CST (in 32159.932s), with 3 more jobs pending
+1053ms ╚Event processed successfully (1053ms)
1/6/2021, 11:29:59 PM +96ms
+0ms ╔Received event [Home].time = 1609997400000 with a delay of -904ms
+78ms ║RunTime Analysis CS > 16ms > PS > 4ms > PE > 58ms > CE
+81ms ║Runtime (53478 bytes) successfully initialized in 4ms (v0.3.110.20191009) (80ms)
+89ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609912800000, d:2, vt:string]]]
+94ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+100ms ║║Comparison (date) 1609912800000 is (date) 1618981200000 = false (3ms)
+105ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+109ms ║║Comparison (date) 1609912800000 is (date) 1625374800000 = false (2ms)
+114ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+118ms ║║Comparison (date) 1609912800000 is (date) 1627448400000 = false (2ms)
+123ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+128ms ║║Comparison (date) 1609912800000 is (date) 1635138000000 = false (3ms)
+133ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+137ms ║║Comparison (date) 1609912800000 is (date) 1635656400000 = false (2ms)
+142ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+148ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+153ms ║║Comparison (date) 1609912800000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (3ms)
+158ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+162ms ║║Comparison (date) 1609912800000 is (date) 1613282400000 = false (2ms)
+167ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+171ms ║║Comparison (date) 1609912800000 is (date) 1617166800000 = false (2ms)
+176ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+180ms ║║Comparison (date) 1609912800000 is (date) 1609912800000 = true (2ms)
+182ms ║║Cancelling statement #107’s schedules…
+187ms ║║Executed virtual command setVariable (2ms)
+224ms ║║Comparison (time) 84599286 happens_daily_at (time) 1609973280000 = false (0ms)
+225ms ║║Condition #56 evaluated false (35ms)
+226ms ║║Cancelling statement #56’s schedules…
+230ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 4:48:00 PM CST
+232ms ║║Condition group #55 evaluated false (state did not change) (42ms)
+236ms ║║Comparison (time) 84599330 happens_daily_at (time) 79200000 = false (0ms)
+237ms ║║Cancelling condition #79’s schedules…
+238ms ║║Condition #79 evaluated false (4ms)
+239ms ║║Cancelling statement #79’s schedules…
+242ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 10:00:00 PM CST
+244ms ║║Cancelling condition #78’s schedules…
+245ms ║║Condition group #78 evaluated false (state changed) (11ms)
+249ms ║║Comparison (time) 84599343 happens_daily_at (time) 84600000 = true (0ms)
+251ms ║║Time restriction check failed
+252ms ║║Condition #81 evaluated false (5ms)
+253ms ║║Cancelling statement #81’s schedules…
+256ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 11:30:00 PM CST
+258ms ║║Condition group #80 evaluated false (state did not change) (11ms)
+264ms ║║Comparison (time) 84599357 happens_daily_at (time) 1609941180000 = false (0ms)
+265ms ║║Condition #73 evaluated false (3ms)
+266ms ║║Cancelling statement #73’s schedules…
+270ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 7:53:00 AM CST
+272ms ║║Condition group #72 evaluated false (state did not change) (11ms)
+275ms ║╚Execution stage complete. (193ms)
+277ms ║Setting up scheduled job for Thu, Jan 7 2021 @ 7:53:00 AM CST (in 30180.627s), with 3 more jobs pending
+284ms ╚Event processed successfully (283ms)
1/6/2021, 9:59:59 PM +223ms
+1ms ╔Received event [Home].time = 1609992000000 with a delay of -777ms
+116ms ║RunTime Analysis CS > 22ms > PS > 5ms > PE > 88ms > CE
+119ms ║Runtime (53479 bytes) successfully initialized in 5ms (v0.3.110.20191009) (118ms)
+131ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609912800000, d:5, vt:string]]]
+136ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+142ms ║║Comparison (date) 1609912800000 is (date) 1618981200000 = false (3ms)
+148ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+152ms ║║Comparison (date) 1609912800000 is (date) 1625374800000 = false (2ms)
+157ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+162ms ║║Comparison (date) 1609912800000 is (date) 1627448400000 = false (2ms)
+167ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+172ms ║║Comparison (date) 1609912800000 is (date) 1635138000000 = false (3ms)
+177ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+182ms ║║Comparison (date) 1609912800000 is (date) 1635656400000 = false (2ms)
+187ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+193ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+198ms ║║Comparison (date) 1609912800000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (3ms)
+203ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+208ms ║║Comparison (date) 1609912800000 is (date) 1613282400000 = false (3ms)
+213ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+218ms ║║Comparison (date) 1609912800000 is (date) 1617166800000 = false (3ms)
+223ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+227ms ║║Comparison (date) 1609912800000 is (date) 1609912800000 = true (2ms)
+230ms ║║Cancelling statement #107’s schedules…
+277ms ║║Comparison (time) 79199461 happens_daily_at (time) 1609973280000 = false (0ms)
+279ms ║║Cancelling condition #56’s schedules…
+280ms ║║Condition #56 evaluated false (42ms)
+284ms ║║Cancelling statement #56’s schedules…
+288ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 4:48:00 PM CST
+290ms ║║Cancelling condition #55’s schedules…
+291ms ║║Condition group #55 evaluated false (state changed) (54ms)
+296ms ║║Comparison (time) 79199517 happens_daily_at (time) 79200000 = true (0ms)
+297ms ║║Time restriction check passed
+298ms ║║Cancelling condition #79’s schedules…
+299ms ║║Condition #79 evaluated true (6ms)
+314ms ║║Cancelling statement #79’s schedules…
+317ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 10:00:00 PM CST
+320ms ║║Cancelling condition #78’s schedules…
+321ms ║║Condition group #78 evaluated true (state changed) (27ms)
+323ms ║║Cancelling statement #86’s schedules…
+6287ms ║║Executed physical command [Outside Light 01].setLevel([10]) (5958ms)
+6288ms ║║Executed [Outside Light 01].setLevel (5960ms)
+6306ms ║║Executed physical command [Outside Light 02].setLevel([10]) (16ms)
+6307ms ║║Executed [Outside Light 02].setLevel (18ms)
+6326ms ║║Executed physical command [Outside Light 03].setLevel([10]) (17ms)
+6328ms ║║Executed [Outside Light 03].setLevel (19ms)
+6347ms ║║Executed physical command [Outside Light 04].setLevel([10]) (17ms)
+6348ms ║║Executed [Outside Light 04].setLevel (19ms)
+6351ms ║║Cancelling statement #88’s schedules…
+6362ms ║║Executed physical command [Gardenspot mini RGB].setLevel([30]) (7ms)
+6364ms ║║Executed [Gardenspot mini RGB].setLevel (9ms)
+6369ms ║║Comparison (time) 79205590 happens_daily_at (time) 1609941180000 = false (0ms)
+6370ms ║║Condition #73 evaluated false (3ms)
+6372ms ║║Cancelling statement #73’s schedules…
+6377ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 7:53:00 AM CST
+6380ms ║║Condition group #72 evaluated false (state did not change) (13ms)
+6383ms ║╚Execution stage complete. (6264ms)
+6385ms ║Setting up scheduled job for Wed, Jan 6 2021 @ 11:30:00 PM CST (in 5394.393s), with 3 more jobs pending
+6392ms ╚Event processed successfully (6392ms)
1/6/2021, 4:47:59 PM +53ms
+0ms ╔Received event [Home].time = 1609973280000 with a delay of -947ms
+78ms ║RunTime Analysis CS > 19ms > PS > 5ms > PE > 54ms > CE
+81ms ║Runtime (53475 bytes) successfully initialized in 5ms (v0.3.110.20191009) (80ms)
+94ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609912800000, d:3, vt:string]]]
+102ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+108ms ║║Comparison (date) 1609912800000 is (date) 1618981200000 = false (4ms)
+113ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+117ms ║║Comparison (date) 1609912800000 is (date) 1625374800000 = false (2ms)
+123ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+128ms ║║Comparison (date) 1609912800000 is (date) 1627448400000 = false (2ms)
+134ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+138ms ║║Comparison (date) 1609912800000 is (date) 1635138000000 = false (2ms)
+143ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+148ms ║║Comparison (date) 1609912800000 is (date) 1635656400000 = false (2ms)
+153ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+159ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+164ms ║║Comparison (date) 1609912800000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (2ms)
+169ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+173ms ║║Comparison (date) 1609912800000 is (date) 1613282400000 = false (2ms)
+178ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+183ms ║║Comparison (date) 1609912800000 is (date) 1617166800000 = false (2ms)
+187ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+192ms ║║Comparison (date) 1609912800000 is (date) 1609912800000 = true (2ms)
+194ms ║║Cancelling statement #107’s schedules…
+199ms ║║Executed virtual command setVariable (2ms)
+235ms ║║Comparison (time) 60479255 happens_daily_at (time) 1609973280000 = true (1ms)
+236ms ║║Time restriction check passed
+237ms ║║Cancelling condition #56’s schedules…
+238ms ║║Condition #56 evaluated true (37ms)
+239ms ║║Cancelling statement #56’s schedules…
+243ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 4:48:00 PM CST
+245ms ║║Cancelling condition #55’s schedules…
+246ms ║║Condition group #55 evaluated true (state changed) (45ms)
+248ms ║║Cancelling statement #57’s schedules…
+739ms ║║Executed physical command [Outside Light 01].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (486ms)
+740ms ║║Executed [Outside Light 01].setColor (488ms)
+757ms ║║Executed physical command [Outside Light 01].setLevel([100]) (15ms)
+758ms ║║Executed [Outside Light 01].setLevel (15ms)
+760ms ║║Cancelling statement #60’s schedules…
+780ms ║║Executed physical command [Outside Light 02].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (16ms)
+781ms ║║Executed [Outside Light 02].setColor (17ms)
+796ms ║║Executed physical command [Outside Light 02].setLevel([100]) (12ms)
+796ms ║║Executed [Outside Light 02].setLevel (13ms)
+799ms ║║Cancelling statement #63’s schedules…
+816ms ║║Executed physical command [Outside Light 03].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (13ms)
+816ms ║║Executed [Outside Light 03].setColor (14ms)
+830ms ║║Executed physical command [Outside Light 03].setLevel([100]) (11ms)
+831ms ║║Executed [Outside Light 03].setLevel (12ms)
+834ms ║║Cancelling statement #66’s schedules…
+851ms ║║Executed physical command [Outside Light 04].setColor([[hex: #DAF17E, hue:20, saturation:20, level:72]]) (13ms)
+851ms ║║Executed [Outside Light 04].setColor (15ms)
+866ms ║║Executed physical command [Outside Light 04].setLevel([100]) (12ms)
+867ms ║║Executed [Outside Light 04].setLevel (13ms)
+869ms ║║Cancelling statement #69’s schedules…
+877ms ║║Executed physical command [Gardenspot mini RGB].setColor([[hex: #0000FF, hue:67, saturation:100, level:50]]) (4ms)
+878ms ║║Executed [Gardenspot mini RGB].setColor (5ms)
+886ms ║║Executed physical command [Gardenspot mini RGB].setLevel([100]) (6ms)
+887ms ║║Executed [Gardenspot mini RGB].setLevel (6ms)
+889ms ║║Cancelling statement #76’s schedules…
+896ms ║║Skipped execution of physical command [Exterior Front].off([]) because it would make no change to the device. (3ms)
+897ms ║║Executed virtual command [Exterior Front].setSwitch (5ms)
+902ms ║║Comparison (time) 60479952 happens_daily_at (time) 1609941180000 = false (0ms)
+903ms ║║Cancelling condition #73’s schedules…
+904ms ║║Condition #73 evaluated false (4ms)
+905ms ║║Cancelling statement #73’s schedules…
+909ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 7:53:00 AM CST
+911ms ║║Cancelling condition #72’s schedules…
+912ms ║║Condition group #72 evaluated false (state changed) (12ms)
+917ms ║╚Execution stage complete. (835ms)
+919ms ║Setting up scheduled job for Wed, Jan 6 2021 @ 10:00:00 PM CST (in 18720.029s), with 3 more jobs pending
+926ms ╚Event processed successfully (926ms)
1/6/2021, 7:52:59 AM +56ms
+0ms ╔Received event [Home].time = 1609941180000 with a delay of -944ms
+76ms ║RunTime Analysis CS > 17ms > PS > 4ms > PE > 54ms > CE
+79ms ║Runtime (53487 bytes) successfully initialized in 4ms (v0.3.110.20191009) (78ms)
+87ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609912800000, d:2, vt:string]]]
+92ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+97ms ║║Comparison (date) 1609912800000 is (date) 1618981200000 = false (3ms)
+102ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+106ms ║║Comparison (date) 1609912800000 is (date) 1625374800000 = false (2ms)
+111ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+116ms ║║Comparison (date) 1609912800000 is (date) 1627448400000 = false (2ms)
+121ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+125ms ║║Comparison (date) 1609912800000 is (date) 1635138000000 = false (2ms)
+130ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+134ms ║║Comparison (date) 1609912800000 is (date) 1635656400000 = false (2ms)
+139ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+146ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+151ms ║║Comparison (date) 1609912800000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (2ms)
+156ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+160ms ║║Comparison (date) 1609912800000 is (date) 1613282400000 = false (2ms)
+165ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+169ms ║║Comparison (date) 1609912800000 is (date) 1617166800000 = false (2ms)
+174ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+179ms ║║Comparison (date) 1609912800000 is (date) 1609912800000 = true (3ms)
+181ms ║║Cancelling statement #107’s schedules…
+186ms ║║Executed virtual command setVariable (3ms)
+223ms ║║Comparison (time) 28379245 happens_daily_at (time) 1609973280000 = false (0ms)
+224ms ║║Condition #56 evaluated false (35ms)
+225ms ║║Cancelling statement #56’s schedules…
+230ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 4:48:00 PM CST
+232ms ║║Condition group #55 evaluated false (state did not change) (44ms)
+236ms ║║Comparison (time) 28379290 happens_daily_at (time) 79200000 = false (0ms)
+237ms ║║Condition #79 evaluated false (3ms)
+241ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 10:00:00 PM CST
+244ms ║║Condition group #78 evaluated false (state did not change) (9ms)
+248ms ║║Comparison (time) 28379302 happens_daily_at (time) 84600000 = false (1ms)
+249ms ║║Condition #81 evaluated false (3ms)
+251ms ║║Cancelling statement #81’s schedules…
+254ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 11:30:00 PM CST
+256ms ║║Condition group #80 evaluated false (state did not change) (11ms)
+262ms ║║Comparison (time) 28379315 happens_daily_at (time) 1609941180000 = true (0ms)
+263ms ║║Time restriction check passed
+264ms ║║Cancelling condition #73’s schedules…
+265ms ║║Condition #73 evaluated true (6ms)
+267ms ║║Cancelling statement #73’s schedules…
+271ms ║║Requesting time schedule wake up at Thu, Jan 7 2021 @ 7:53:00 AM CST
+274ms ║║Cancelling condition #72’s schedules…
+275ms ║║Condition group #72 evaluated true (state changed) (15ms)
+277ms ║║Cancelling statement #74’s schedules…
+284ms ║║Skipped execution of physical command [Deck Lights].off([]) because it would make no change to the device. (3ms)
+285ms ║║Executed [Deck Lights].off (5ms)
+290ms ║║Skipped execution of physical command [Exterior Front].off([]) because it would make no change to the device. (3ms)
+291ms ║║Executed [Exterior Front].off (5ms)
+302ms ║║Executed physical command [Gardenspot mini RGB].off() (9ms)
+303ms ║║Executed [Gardenspot mini RGB].off (10ms)
+904ms ║║Executed physical command [Outside Light 01].off() (598ms)
+905ms ║║Executed [Outside Light 01].off (600ms)
+922ms ║║Executed physical command [Outside Light 02].off() (15ms)
+923ms ║║Executed [Outside Light 02].off (17ms)
+941ms ║║Executed physical command [Outside Light 03].off() (15ms)
+942ms ║║Executed [Outside Light 03].off (17ms)
+962ms ║║Executed physical command [Outside Light 04].off() (17ms)
+962ms ║║Executed [Outside Light 04].off (19ms)
+967ms ║╚Execution stage complete. (887ms)
+969ms ║Setting up scheduled job for Wed, Jan 6 2021 @ 4:48:00 PM CST (in 32099.976s), with 3 more jobs pending
+1037ms ╚Event processed successfully (1037ms)
1/5/2021, 11:29:59 PM +72ms
+0ms ╔Received event [Home].time = 1609911000000 with a delay of -928ms
+73ms ║RunTime Analysis CS > 17ms > PS > 10ms > PE > 46ms > CE
+76ms ║Runtime (53487 bytes) successfully initialized in 10ms (v0.3.110.20191009) (75ms)
+77ms ║╔Execution stage started
+89ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609826400000, d:6, vt:string]]]
+101ms ║║Comparison (date) 1609826400000 is (date) 1618981200000 = false (3ms)
+106ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+110ms ║║Comparison (date) 1609826400000 is (date) 1625374800000 = false (2ms)
+116ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+120ms ║║Comparison (date) 1609826400000 is (date) 1627448400000 = false (2ms)
+125ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+129ms ║║Comparison (date) 1609826400000 is (date) 1635138000000 = false (2ms)
+134ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+139ms ║║Comparison (date) 1609826400000 is (date) 1635656400000 = false (2ms)
+143ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+149ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+154ms ║║Comparison (date) 1609826400000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (2ms)
+164ms ║║Comparison (date) 1609826400000 is (date) 1613282400000 = false (2ms)
+173ms ║║Comparison (date) 1609826400000 is (date) 1617166800000 = false (2ms)
+182ms ║║Comparison (date) 1609826400000 is (date) 1609912800000 = false (2ms)
+184ms ║║Cancelling statement #18’s schedules…
+189ms ║║Executed virtual command setVariable (3ms)
+194ms ║║Executed virtual command setVariable (2ms)
+203ms ║║Executed virtual command setVariable (2ms)
+208ms ║║Executed virtual command setVariable (3ms)
+212ms ║║Executed virtual command setVariable (2ms)
+249ms ║║Comparison (time) 84599287 happens_daily_at (time) 1609886820000 = false (1ms)
+250ms ║║Condition #56 evaluated false (35ms)
+251ms ║║Cancelling statement #56’s schedules…
+255ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 4:47:00 PM CST
+257ms ║║Condition group #55 evaluated false (state did not change) (42ms)
+261ms ║║Comparison (time) 84599331 happens_daily_at (time) 79200000 = false (1ms)
+262ms ║║Cancelling condition #79’s schedules…
+263ms ║║Condition #79 evaluated false (4ms)
+264ms ║║Cancelling statement #79’s schedules…
+267ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 10:00:00 PM CST
+269ms ║║Cancelling condition #78’s schedules…
+270ms ║║Condition group #78 evaluated false (state changed) (10ms)
+274ms ║║Comparison (time) 84599344 happens_daily_at (time) 84600000 = true (0ms)
+275ms ║║Time restriction check failed
+276ms ║║Condition #81 evaluated false (4ms)
+277ms ║║Cancelling statement #81’s schedules…
+280ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 11:30:00 PM CST
+282ms ║║Condition group #80 evaluated false (state did not change) (11ms)
+288ms ║║Comparison (time) 84599357 happens_daily_at (time) 1609854780000 = false (0ms)
+289ms ║║Condition #73 evaluated false (3ms)
+290ms ║║Cancelling statement #73’s schedules…
+294ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 7:53:00 AM CST
+296ms ║║Condition group #72 evaluated false (state did not change) (11ms)
+300ms ║╚Execution stage complete. (222ms)
+301ms ║Setting up scheduled job for Wed, Jan 6 2021 @ 7:53:00 AM CST (in 30180.627s), with 3 more jobs pending
+307ms ╚Event processed successfully (307ms)
1/5/2021, 9:59:59 PM +62ms
+0ms ╔Received event [Home].time = 1609905600000 with a delay of -939ms
+126ms ║RunTime Analysis CS > 21ms > PS > 8ms > PE > 98ms > CE
+130ms ║Runtime (53488 bytes) successfully initialized in 8ms (v0.3.110.20191009) (128ms)
+138ms ║║Evaluating switch with values [[i:1:null:0, v:[t:date, v:1609826400000, d:2, vt:string]]]
+144ms ║║Calculating (string) 04/21/ + (string) 2021 >> (string) 04/21/2021
+154ms ║║Comparison (date) 1609826400000 is (date) 1618981200000 = false (5ms)
+162ms ║║Calculating (string) 07/04/ + (string) 2021 >> (string) 07/04/2021
+168ms ║║Comparison (date) 1609826400000 is (date) 1625374800000 = false (3ms)
+174ms ║║Calculating (string) 07/28/ + (string) 2021 >> (string) 07/28/2021
+181ms ║║Comparison (date) 1609826400000 is (date) 1627448400000 = false (2ms)
+189ms ║║Calculating (string) 10/25/ + (string) 2021 >> (string) 10/25/2021
+195ms ║║Comparison (date) 1609826400000 is (date) 1635138000000 = false (3ms)
+203ms ║║Calculating (string) 10/31/ + (string) 2021 >> (string) 10/31/2021
+210ms ║║Comparison (date) 1609826400000 is (date) 1635656400000 = false (4ms)
+218ms ║║Calculating (string) 12/01/ + (string) 2021 >> (string) 12/01/2021
+229ms ║║Calculating (string) 12/31/ + (string) 2021 >> (string) 12/31/2021
+237ms ║║Comparison (date) 1609826400000 is_inside_of_range (date) 1638338400000 … (date) 1640930400000 = false (4ms)
+246ms ║║Calculating (string) 02/14/ + (string) 2021 >> (string) 02/14/2021
+253ms ║║Comparison (date) 1609826400000 is (date) 1613282400000 = false (4ms)
+261ms ║║Calculating (string) 03/31/ + (string) 2021 >> (string) 03/31/2021
+269ms ║║Comparison (date) 1609826400000 is (date) 1617166800000 = false (4ms)
+277ms ║║Calculating (string) 01/06/ + (string) 2021 >> (string) 01/06/2021
+282ms ║║Comparison (date) 1609826400000 is (date) 1609912800000 = false (3ms)
+284ms ║║Cancelling statement #18’s schedules…
+290ms ║║Executed virtual command setVariable (3ms)
+295ms ║║Executed virtual command setVariable (2ms)
+300ms ║║Executed virtual command setVariable (3ms)
+307ms ║║Executed virtual command setVariable (3ms)
+312ms ║║Executed virtual command setVariable (2ms)
+316ms ║║Executed virtual command setVariable (2ms)
+358ms ║║Comparison (time) 79199381 happens_daily_at (time) 1609886820000 = false (0ms)
+360ms ║║Condition #56 evaluated false (40ms)
+361ms ║║Cancelling statement #56’s schedules…
+369ms ║║Requesting time schedule wake up at Wed, Jan 6 2021 @ 4:47:00 PM CST
