Local variable containing the name of a global variable works for retrieving the value but unable to set through the same indirection
define localVariable="@globalVariableName"
set variable({{localVariable}}) = newValue would set the Global variable who’s name is stored in the local variable to the new value
Only able to pick the actual variable objects in the GUI - there is no expression option to be able to perform this indirection
N/A
N/A
