If i create a set of physical devices in a variable for use by foreach, the variable does not subscribe to events…is that expected ? I have since rewritten as 3 separate pistons but would like to understand if I should have been able to do in a for loop
I expect that I could check devices in a for loop ( in this case “stays open”)
I get the msg This piston does not subscribe to any events
sorry I didnt even get running…are logs of any use?
