This piston is designed to notify a visitor to the porch when the sensor activates. To help prevent false notifications, this is suppressed for a few mins if we have arrived home, or walked up to the front door from inside (hall sensor)
The multiple scheduled tasks on the with sensor/presence increment a variable when there is activity. This prevents the notification if the porch sensor is activated. After a wait, the variable is decremented. The same variable is used (with 5 min wait) to prevent multiple notifications, and also if the porch senses movement when the counter is not 0 (i.e we’ve just arrived home or are leaving)
The piston is working well most of the time. However, occasionally, the notify variable has a value of -1. (hence condition =< 0 on line 23) I can’t see how notify can ever get to a value of -1, unless a multi scheduled task is not fully running, or there is a semaphore issue where two tasks try to set the variable at the same time?
Is this a bug, or am I doing something wrong/not understanding?
nothing in the logs
