Piston to control a switch that turns on/off a hot water circulator. Overall this switch should get turned on in the AM, off when household is at work/school, on in evening, off when asleep. I have tried to insert comments to demonstrate. With each “action”, I have tried to get update a variable with what/when the action occurred. This does not seem to be updating with events. It updates when I switch on/off the “guest mode” switch and when I run a piston test.
Described above. Two variables should be updated when piston directs switch to be turned on/off.
Variables (LastEvent and LastEventTime) not updated as expected. They do update appropriately with guest mode switch (is a virtual ST on/off switch) being turned on/off, but not the other events that are time-based or lack of motion based.
Let me know if logs will help but I think I am just missing something with the way the code is written.
