Verbal Responses from Alexa
Hey all,
I am in the very early design stages here. But I’m wondering if this is something, I can set up with some add ins.
Let me know if this should be in the Smartthings forum, if that’s more the venue for this?
I want to set up a piston where:
If, the living temp sensor hits 26c then it will check if all the doors/ window sensors are closed.
if they are, turn on the Aircon (swichbot device) till the temp drops to 23c and then turn Aircon off.
Else, verbally from all Alexa devices advise which specified door sensors are open
Is something like this doable? And can someone point me in the right direction in terms of smart apps ect that I would need?
Thanks guys!
Definitely doable in webcore. You will probably need Voicemonkey.
