I have my routines like Good Morning and Good night set to a virtual switch. For example I have a virtual switch called Good Morning and I can say Hey google turn on Good Morning. Then I have a piston set to do certain things when that virtual switch turns on. It has been working for about a year. And now it stopped working in the logs it says Condition group #1 evaluated false (state changed). Can anyone help me with this? I have the same problem with Good night.
Here are the logs and pistons
The piston should run once the virtual switch is turned on.
Nothing is running.
6/26/2020, 6:15:35 AM +530ms
+1ms ╔Received event [Good morning].switch = off with a delay of 74ms
+160ms ║RunTime Analysis CS > 21ms > PS > 91ms > PE > 48ms > CE
+163ms ║Runtime (37938 bytes) successfully initialized in 91ms (v0.3.110.20191009) (160ms)
+163ms ║╔Execution stage started
+170ms ║║Comparison (enum) off changes_to (string) on = false (1ms)
+172ms ║║Cancelling condition #2’s schedules…
+172ms ║║Condition #2 evaluated false (5ms)
+173ms ║║Cancelling condition #1’s schedules…
+174ms ║║Condition group #1 evaluated false (state changed) (7ms)
+176ms ║╚Execution stage complete. (13ms)
+177ms ╚Event processed successfully (177ms)
