I’m working on using a virtual thermostat to control my window air conditioner via webCoRE for when summertime comes. I’ve got the temperature and humidity being fed to the thermostat by a multisensor, but only the temperature is being updated in the thermostat. Can anyone help with why the humidity isn’t working?
Virtual thermostat temperature and humidity to be updated via Aeotec Multisensor 6
Temperature updates, humidity doesn’t
LOGS
12/25/2017, 9:43:46 PM +75ms
+1ms ╔Received event [Thermostat].temperature = 74.3 with a delay of 65ms
+9417ms ║RunTime Analysis CS > 19ms > PS > 9329ms > PE > 69ms > CE
+9418ms ║Piston waited at a semaphore for 9265ms
+9419ms ║Runtime (39581 bytes) successfully initialized in 9329ms (v0.2.100.20171211) (9418ms)
+9420ms ║╔Execution stage started
+9424ms ║║Cancelling statement #1’s schedules…
+9456ms ║║Executed physical command [Thermostat].setTemperature([74.3]) (24ms)
+9457ms ║║Executed [Thermostat].setTemperature (25ms)
+9488ms ║║Executed physical command [Thermostat].setHumidityPercent([28]) (25ms)
+9489ms ║║Executed [Thermostat].setHumidityPercent (27ms)
+9496ms ║║Comparison (decimal) 74.3 is_greater_than_or_equal_to (decimal) 71.0 = true (1ms)
+9497ms ║║Condition #11 evaluated true (6ms)
+9498ms ║║Condition group #4 evaluated true (state did not change) (7ms)
+9500ms ║║Cancelling statement #5’s schedules…
+9505ms ║║Skipped execution of physical command [Christmas Lights].on([]) because it would make no change to the device. (3ms)
+9506ms ║║Executed [Christmas Lights].on (3ms)
+9513ms ║║Comparison (decimal) 74.3 is_less_than_or_equal_to (decimal) 67.0 = false (1ms)
+9514ms ║║Condition #10 evaluated false (6ms)
+9515ms ║║Condition group #7 evaluated false (state did not change) (8ms)
+9517ms ║╚Execution stage complete. (97ms)
+9518ms ╚Event processed successfully (9518ms)
12/25/2017, 9:43:45 PM +275ms
