made a dummy piston:
It still has same problem. Sensor does not have delay. It’s closing and opening almost immediately…maybe 1 sec off max.
Took some log:
28.12.2019 klo 19.27.18 +114ms
+0ms ╔Received event [Koti].time = 1577554039935 with a delay of -1822ms
+77ms ║Runtime (36612 bytes) successfully initialized in 41ms (v0.3.110.20191009) (76ms)
+78ms ║╔Execution stage started
+79ms ║╚Execution stage complete. (1ms)
+80ms ╚Event processed successfully (80ms)
28.12.2019 klo 19.26.52 +738ms
+1ms ╔Received event [Open Close Sensor Front Door].contact = closed with a delay of 84ms
+49ms ║Runtime (36622 bytes) successfully initialized in 20ms (v0.3.110.20191009) (46ms)
+60ms ║╚Execution stage complete. (11ms)
+61ms ╚Event processed successfully (61ms)
28.12.2019 klo 19.26.49 +831ms
+1ms ╔Received event [Open Close Sensor Front Door].contact = open with a delay of 117ms
+51ms ║Runtime (36628 bytes) successfully initialized in 24ms (v0.3.110.20191009) (49ms)
+52ms ║╔Execution stage started
+98ms ║║Executed virtual command sendPushNotification (34ms)
+102ms ║║Executed virtual command wait (1ms)
+103ms ║║Requesting a wake up for Sat, Dec 28 2019 @ 7:27:19 PM EET (in 30.0s)
+109ms ║╚Execution stage complete. (58ms)
+111ms ║Setting up scheduled job for Sat, Dec 28 2019 @ 7:27:19 PM EET (in 29.994s)
+122ms ╚Event processed successfully (122ms)
28.12.2019 klo 19.26.43 +168ms
+1ms ╔Received event [Open Close Sensor Front Door].contact = closed with a delay of 125ms
+80ms ║Runtime (36623 bytes) successfully initialized in 39ms (v0.3.110.20191009) (78ms)
+94ms ║╚Execution stage complete. (12ms)
+95ms ╚Event processed successfully (95ms)
28.12.2019 klo 19.26.38 +967ms
+1ms ╔Received event [Open Close Sensor Front Door].contact = open with a delay of 104ms
+54ms ║Runtime (36628 bytes) successfully initialized in 27ms (v0.3.110.20191009) (52ms)
+55ms ║╔Execution stage started
+82ms ║║Executed virtual command sendPushNotification (15ms)
+85ms ║║Executed virtual command wait (1ms)
+86ms ║║Requesting a wake up for Sat, Dec 28 2019 @ 7:27:09 PM EET (in 30.0s)
+91ms ║╚Execution stage complete. (35ms)
+92ms ║Setting up scheduled job for Sat, Dec 28 2019 @ 7:27:09 PM EET (in 29.995s)
+103ms ╚Event processed successfully (102ms)
If I understand this right piston resets when sensor is closed. Are you guys understanding this same way or do you see other weird shit in it?
