This piston supervises the garage door. If left open for a long duration it will close it. The duration for use will be longer (25 minutes), however, for testing it is currently at 2 minutes. The closing of the garage door is accomplished by a garage door remote that I have connected to a smart outlet. This all works well.
HOWEVER, what does not work is the 24-hour lockout. On the trace I see the 24-hour wait start counting but when the garage contact is closed it breaks the wait loop and is ready to start another supervisory period if the contact is opened.
I have tried everything: making the WHILE clause never break, the WITH clause never break, the IF clause automatic subscribe or always subscribe.
Why is the 24-hour wait being interrupted? Seems like it should not.
Thanks in advance
Cheers, Ray
(PUT YOUR INFO HERE)
(UPLOAD YOUR IMAGE HERE)
8/14/2019, 10:40:19 AM +430ms
+2ms âReceived event [Desk Chair].contact = closed with a delay of 95ms
+95ms âRunTime Analysis CS > 21ms > PS > 48ms > PE > 25ms > CE
+97ms âRuntime (44303 bytes) successfully initialized in 48ms (v0.3.10e.20190628) (95ms)
+98ms ââExecution stage started
+108ms ââComparison (enum) closed changes_to (string) open = false (1ms)
+110ms ââCancelling condition #3âs schedulesâŚ
+110ms ââCondition #3 evaluated false (7ms)
+111ms ââCancelling condition #2âs schedulesâŚ
+112ms ââCondition group #2 evaluated false (state changed) (9ms)
+113ms ââCancelling condition #1âs schedulesâŚ
+114ms ââCondition group #1 evaluated false (state changed) (12ms)
+117ms ââExecution stage complete. (19ms)
+119ms âSetting up scheduled job for Thu, Aug 15 2019 @ 10:39:48 AM EDT (in 86369.28s)
+131ms âEvent processed successfully (131ms)
8/14/2019, 10:40:08 AM +512ms
+1ms âReceived event [Desk Chair].contact = open with a delay of 108ms
+92ms âRunTime Analysis CS > 22ms > PS > 47ms > PE > 23ms > CE
+94ms âRuntime (44310 bytes) successfully initialized in 47ms (v0.3.10e.20190628) (92ms)
+95ms ââExecution stage started
+105ms ââComparison (enum) open changes_to (string) open = true (1ms)
+107ms ââCancelling condition #3âs schedulesâŚ
+108ms ââCondition #3 evaluated true (7ms)
+113ms ââComparison (boolean) false is_not (boolean) true = true (2ms)
+115ms ââCondition #4 evaluated true (6ms)
+116ms ââCancelling condition #2âs schedulesâŚ
+116ms ââCondition group #2 evaluated true (state changed) (16ms)
+117ms ââCancelling condition #1âs schedulesâŚ
+118ms ââCondition group #1 evaluated true (state changed) (19ms)
+122ms ââCancelling statement #6âs schedulesâŚ
+127ms ââExecuted virtual command setVariable (3ms)
+135ms ââComparison (enum) open is (string) open = true (1ms)
+137ms ââCondition #9 evaluated true (7ms)
+143ms ââComparison (boolean) false is_not (boolean) true = true (2ms)
+144ms ââCondition #10 evaluated true (6ms)
+145ms ââCondition group #8 evaluated true (state did not change) (15ms)
+148ms ââCancelling statement #11âs schedulesâŚ
+153ms ââCalculating (integer) 0 + (integer) 1 >> (integer) 1
+158ms ââExecuted virtual command setVariable (3ms)
+163ms ââExecuted virtual command wait (1ms)
+164ms ââRequesting a wake up for Wed, Aug 14 2019 @ 10:41:08 AM EDT (in 60.0s)
+170ms ââExecution stage complete. (75ms)
+172ms âSetting up scheduled job for Wed, Aug 14 2019 @ 10:41:08 AM EDT (in 59.994s), with 1 more job pending
+185ms âEvent processed successfully (185ms)
8/14/2019, 10:39:56 AM +3ms
+1ms âReceived event [Desk Chair].contact = closed with a delay of 96ms
+105ms âRunTime Analysis CS > 30ms > PS > 52ms > PE > 23ms > CE
+108ms âRuntime (44304 bytes) successfully initialized in 52ms (v0.3.10e.20190628) (106ms)
+109ms ââExecution stage started
+118ms ââComparison (enum) closed changes_to (string) open = false (1ms)
+120ms ââCancelling condition #3âs schedulesâŚ
+121ms ââCondition #3 evaluated false (6ms)
+122ms ââCancelling condition #2âs schedulesâŚ
+123ms ââCondition group #2 evaluated false (state changed) (9ms)
+124ms ââCancelling condition #1âs schedulesâŚ
+124ms ââCondition group #1 evaluated false (state changed) (11ms)
+127ms ââExecution stage complete. (18ms)
+128ms âSetting up scheduled job for Thu, Aug 15 2019 @ 10:39:48 AM EDT (in 86392.697s)
+140ms âEvent processed successfully (140ms)
8/14/2019, 10:39:47 AM +121ms
+0ms âReceived event [Home].time = 1565793588244 with a delay of -1124ms
+90ms âRunTime Analysis CS > 26ms > PS > 43ms > PE > 21ms > CE
+92ms âRuntime (44306 bytes) successfully initialized in 43ms (v0.3.10e.20190628) (91ms)
+93ms ââExecution stage started
+112ms ââComparison (integer) 2 is_equal_to (integer) 2 = true (1ms)
+114ms ââCancelling condition #15âs schedulesâŚ
+115ms ââCondition #15 evaluated true (6ms)
+116ms ââCancelling condition #14âs schedulesâŚ
+117ms ââCondition group #14 evaluated true (state changed) (8ms)
+120ms ââCancelling statement #17âs schedulesâŚ
+136ms ââExecuted physical command [Bedroom Light].on() (12ms)
+137ms ââExecuted [Bedroom Light].on (14ms)
+143ms ââExecuted virtual command [Bedroom Light].wait (1ms)
+145ms ââWaiting for 1500ms
+1658ms ââExecuted physical command [Bedroom Light].off() (10ms)
+1659ms ââExecuted [Bedroom Light].off (12ms)
+1663ms ââExecuted virtual command [Bedroom Light].setVariable (1ms)
+1700ms ââExecuted virtual command [Bedroom Light].sendSMSNotification (30ms)
+1705ms ââExecuted virtual command [Bedroom Light].wait (0ms)
+1706ms ââRequesting a wake up for Thu, Aug 15 2019 @ 10:39:48 AM EDT (in 86400.0s)
+1711ms ââExecution stage complete. (1618ms)
+1713ms âSetting up scheduled job for Thu, Aug 15 2019 @ 10:39:48 AM EDT (in 86399.995s)
+1721ms âEvent processed successfully (1720ms)
8/14/2019, 10:38:48 AM +84ms
+1ms âReceived event [Home].time = 1565793529914 with a delay of -1830ms
+87ms âRunTime Analysis CS > 19ms > PS > 45ms > PE > 23ms > CE
+90ms âRuntime (44304 bytes) successfully initialized in 45ms (v0.3.10e.20190628) (88ms)
+91ms ââExecution stage started
+113ms ââComparison (integer) 1 is_equal_to (integer) 2 = false (2ms)
+115ms ââCancelling condition #15âs schedulesâŚ
+116ms ââCondition #15 evaluated false (7ms)
+117ms ââCancelling condition #14âs schedulesâŚ
+118ms ââCondition group #14 evaluated false (state changed) (10ms)
+130ms ââComparison (enum) open is (string) open = true (2ms)
+132ms ââCondition #9 evaluated true (11ms)
+138ms ââComparison (boolean) false is_not (boolean) true = true (2ms)
+139ms ââCondition #10 evaluated true (6ms)
+140ms ââCondition group #8 evaluated true (state did not change) (21ms)
+143ms ââCancelling statement #11âs schedulesâŚ
+149ms ââCalculating (integer) 1 + (integer) 1 >> (integer) 2
+154ms ââExecuted virtual command setVariable (3ms)
+158ms ââExecuted virtual command wait (1ms)
+159ms ââRequesting a wake up for Wed, Aug 14 2019 @ 10:39:48 AM EDT (in 60.0s)
+164ms ââExecution stage complete. (73ms)
+166ms âSetting up scheduled job for Wed, Aug 14 2019 @ 10:39:48 AM EDT (in 59.995s)
+173ms âEvent processed successfully (173ms)
8/14/2019, 10:37:49 AM +759ms
+1ms âReceived event [Desk Chair].contact = open with a delay of 94ms
+80ms âRunTime Analysis CS > 18ms > PS > 44ms > PE > 19ms > CE
+83ms âRuntime (44311 bytes) successfully initialized in 44ms (v0.3.10e.20190628) (81ms)
+84ms ââExecution stage started
+94ms ââComparison (enum) open changes_to (string) open = true (0ms)
+95ms ââCancelling condition #3âs schedulesâŚ
+96ms ââCondition #3 evaluated true (7ms)
+102ms ââComparison (boolean) false is_not (boolean) true = true (1ms)
+103ms ââCondition #4 evaluated true (6ms)
+104ms ââCancelling condition #2âs schedulesâŚ
+105ms ââCondition group #2 evaluated true (state changed) (16ms)
+106ms ââCancelling condition #1âs schedulesâŚ
+107ms ââCondition group #1 evaluated true (state changed) (19ms)
+110ms ââCancelling statement #6âs schedulesâŚ
+116ms ââExecuted virtual command setVariable (3ms)
+124ms ââComparison (enum) open is (string) open = true (1ms)
+126ms ââCancelling condition #9âs schedulesâŚ
+127ms ââCondition #9 evaluated true (8ms)
+132ms ââComparison (boolean) false is_not (boolean) true = true (1ms)
+134ms ââCondition #10 evaluated true (6ms)
+135ms ââCancelling condition #8âs schedulesâŚ
+136ms ââCondition group #8 evaluated true (state changed) (18ms)
+138ms ââCancelling statement #11âs schedulesâŚ
+143ms ââCalculating (integer) 0 + (integer) 1 >> (integer) 1
+148ms ââExecuted virtual command setVariable (3ms)
+153ms ââExecuted virtual command wait (0ms)
+154ms ââRequesting a wake up for Wed, Aug 14 2019 @ 10:38:49 AM EDT (in 60.0s)
+159ms ââExecution stage complete. (75ms)
+161ms âSetting up scheduled job for Wed, Aug 14 2019 @ 10:38:49 AM EDT (in 59.995s)
+174ms âEvent processed successfully (175ms)
If a solution is found for your question then please mark the post as the solution.emphasized text
