Another instance of the wait timer on my piston suddenly stopped working. I’ve read a lot about setting the TCP to never, but I can’t seem to get it working again.
I have an automation in my bathroom that if 1) motion is detected on a sensor or 2) the toilet is open, then the lights come on. Then if 1) motion sensors are inactive or 3) the toilet is closed, then wait 2 minutes and shut off the lights.
The timer is never starting, the lights just stay on forever.
3/10/2021, 3:01:08 PM +358ms +1ms ╔Received event [Bathroom Door Sensor].motion = inactive with a delay of 55ms +54ms ║RunTime Analysis CS > 15ms > PS > 6ms > PE > 32ms > CE +56ms ║Runtime (40120 bytes) successfully initialized in 6ms (v0.3.113.20210203) (54ms) +57ms ║╔Execution stage started +70ms ║║Comparison (time) 54068419 is_between (time) 20700000 .. (time) 75600000 = true (8ms) +71ms ║║Time restriction check passed +73ms ║║Condition #1 evaluated true (13ms) +74ms ║║Condition group #null evaluated true (state did not change) (14ms) +87ms ║║Comparison (enum) inactive is (string) active = false (1ms) +89ms ║║Comparison (enum) active is (string) active = true (1ms) +91ms ║║Condition #15 evaluated true (14ms) +92ms ║║Condition group #14 evaluated true (state did not change) (15ms) +93ms ║║Condition group #2 evaluated true (state did not change) (17ms) +96ms ║║Cancelling statement #6's schedules... +103ms ║║Skipped execution of physical command [Bath Bulb 1].on([]) because it would make no change to the device. (4ms) +105ms ║║Executed [Bath Bulb 1].on (6ms) +111ms ║║Skipped execution of physical command [Bath Bulb 2].on([]) because it would make no change to the device. (4ms) +112ms ║║Executed [Bath Bulb 2].on (6ms) +118ms ║║Skipped execution of physical command [Bath Bulb 3].on([]) because it would make no change to the device. (3ms) +119ms ║║Executed [Bath Bulb 3].on (5ms) +130ms ║║Skipped execution of physical command [Bath Bulb 1].setLevel([100]) because it would make no change to the device. (6ms) +131ms ║║Executed [Bath Bulb 1].setLevel (8ms) +139ms ║║Skipped execution of physical command [Bath Bulb 2].setLevel([100]) because it would make no change to the device. (7ms) +140ms ║║Executed [Bath Bulb 2].setLevel (8ms) +149ms ║║Skipped execution of physical command [Bath Bulb 3].setLevel([100]) because it would make no change to the device. (7ms) +150ms ║║Executed [Bath Bulb 3].setLevel (9ms) +153ms ║╚Execution stage complete. (96ms) +154ms ╚Event processed successfully (154ms) 3/10/2021, 3:00:37 PM +712ms +1ms ╔Received event [Bathroom Door Sensor].motion = active with a delay of 61ms +64ms ║RunTime Analysis CS > 15ms > PS > 6ms > PE > 42ms > CE +66ms ║Runtime (40120 bytes) successfully initialized in 6ms (v0.3.113.20210203) (64ms) +67ms ║╔Execution stage started +79ms ║║Comparison (time) 54037783 is_between (time) 20700000 .. (time) 75600000 = true (7ms) +80ms ║║Time restriction check passed +82ms ║║Condition #1 evaluated true (12ms) +83ms ║║Condition group #null evaluated true (state did not change) (13ms) +98ms ║║Comparison (enum) active is (string) active = true (1ms) +99ms ║║Condition #15 evaluated true (13ms) +100ms ║║Condition group #14 evaluated true (state did not change) (15ms) +101ms ║║Condition group #2 evaluated true (state did not change) (16ms) +104ms ║║Cancelling statement #6's schedules... +151ms ║║Executed physical command [Bath Bulb 1].on() (44ms) +152ms ║║Executed [Bath Bulb 1].on (45ms) +163ms ║║Executed physical command [Bath Bulb 2].on() (8ms) +164ms ║║Executed [Bath Bulb 2].on (10ms) +174ms ║║Executed physical command [Bath Bulb 3].on() (8ms) +175ms ║║Executed [Bath Bulb 3].on (10ms) +187ms ║║Executed physical command [Bath Bulb 1].setLevel([100]) (9ms) +188ms ║║Executed [Bath Bulb 1].setLevel (11ms) +199ms ║║Executed physical command [Bath Bulb 2].setLevel([100]) (9ms) +200ms ║║Executed [Bath Bulb 2].setLevel (10ms) +210ms ║║Executed physical command [Bath Bulb 3].setLevel([100]) (9ms) +211ms ║║Executed [Bath Bulb 3].setLevel (11ms) +213ms ║╚Execution stage complete. (146ms) +214ms ╚Event processed successfully (214ms)
