Hello again!
I have a piston that after a certain time of night after motion has stopped I want various things to happen, lights, locks, vacuum. I can do all this easily, however, I want to add the caveat to not run the vacuum until after a certain switch has turned off (if it was on when the piston initially triggered).
Is there a way to trigger the piston normally, but have the vacuum portion of it not run until an extra condition is met?
Thanks as always guys!
