My temperature sensor will only report its temp every hour. I want something to manually check it every 20-30 minutes and then do something with the info.
I would like it to check the temp of the sensor then execute the rest of the piston
I actually don’t understand how to get it to repeat. So I haven’t put that in yet. This is what I need help with. Thanks so much!!
N/A
