This Piston is driving me bonkers because it worked in SmartThings and the exact same one is NOT working in Hubitat.
Issue is only when the Washer and Dryer are both on. When each individually are on then turn off I am getting notified but when both are on, it is not working its way through the last part of the Piston. This is the specific part of the piston that is not working. I cant get the logs right now because Im not doing laundry. I dont really like two triggers together like this, especially ones that require ‘stay less than’ but if anyone has a better way to do it or sees a fix, let me know: Here is the bad section followed by the full piston:
Edit - Found the issue. Usually when you import a piston from ST to Hubitat dashboards (any import of someones Piston really) it xxxxx’s out all of the devices and you have to go in and choose the device you want to use in the new environment. For the variables it does not do that and when I created slightly new nomenclature for the Hubitat Variables I did not change all the old ones that were imported from ST so it really mucked up the Piston.
ISSUE SOLVED
