I am using Echo Speaks on Hubitat, and have a piston that should respond using the echo that was last spoken to. The issue is that while the piston gets called, it is not updating the lastspokentodevice, so it always responds from one (in this case, the one in my office). This did work at one point, but stopped over a year ago, so I just hard-coded in some things as a workaround, but am finally getting some time to look at it.
When you speak to an echo device, it will respond to you using that device. In my case, I have a piston so that when I ask what doors and windows are open, it will speak which ones (or that all are closed).
It is not updating the “lastspokentodevice” so it always responds via the last one it had recorded (from a couple of years ago), which happens to be the one in my office.
10/12/2022, 1:34:50 PM +969ms
+4ms ╔Received event [9011Hub].:df07296575f5dbc1b2f7333da6ffc20c:.@dynLastEchoSpokeToPistonTrigger = @dynLastEchoSpokeToPistonTrigger with a delay of 55ms, canQueue: true, calledMyself: false
+53ms ║RunTime initialize > 52 LockT > 1ms > r9T > 41ms > pistonT > 38ms (first state access 10 5 47)
+56ms ║Runtime (7386 bytes) initialized in 41ms (v0.3.114.20220917_HE)
+59ms ║╔Execution stage started
+69ms ║║Comparison (dynamic) 1665606890827 changes = true (1ms)
+72ms ║║Condition #2 evaluated true (5ms)
+75ms ║║Condition group #1 evaluated true (condition changed) (9ms)
+152ms ║║Executed physical command [Echo - Basement Echo Dot].getDeviceActivity() (68ms)
+218ms ║║Executed physical command [Echo - Dining room echo].getDeviceActivity() (61ms)
+287ms ║║Executed physical command [Echo - MBR Echo].getDeviceActivity() (63ms)
+355ms ║║Executed physical command [Echo - Office Echo Dot].getDeviceActivity() (63ms)
+372ms ║║Comparison (string) false is (boolean) true = false (2ms)
+375ms ║║Comparison (string) false is (boolean) true = false (1ms)
+377ms ║║Comparison (string) false is (boolean) true = false (1ms)
+379ms ║║Comparison (string) false is (boolean) true = false (1ms)
+382ms ║║Condition #6 evaluated false (25ms)
+383ms ║║Condition group #5 evaluated false (condition did not change) (27ms)
+398ms ║║Empty device list
+401ms ║║Executed virtual command log (3ms)
+408ms ║║Device ‘’:null not found
+410ms ║║Executed virtual command log (2ms)
+417ms ║╚Execution stage complete. (360ms)
+423ms ╚Event processed successfully (419ms)
