I’m trying to create a piston that senses that one or more water sensors are wet and then it turns off my water using my Econet Bulldog valve shutoff, but only when the housekeeper isn’t in the house. The housekeeper only comes every other week so this isn’t often. I can almost do this within the old app but not exactly.
Here are my requirements…
- One or more sensor gets wet will trigger this and
- It’s not on a day when the housekeeper is mopping (Because that triggers a lot of them all day long)
- In relation to #2 above how do I tell the piston that the housekeeper is in the house (Can I use a date or a switch of some kind?)
- I’d like not to have to name each of the water sensors, can I just refer to them all like I can in the app? (I’m afraid that if I add a sensor I’ll forget to add it to the IF statement.)
What is the best way to do this in a piston?
