I am trying to define variables for the weather
I want to define “CurrentlyHumid” variable as = ($twcweather.conditions.relativehumidity)
I test it by writing the piston to greater than 90 (should be false) and it stays true.
**5) Attach logs after turning logging level to Full**
11/17/2021, 2:48:01 PM +51ms
+1ms ╔Received event [Home].test = 1637182081050 with a delay of 0ms
+40ms ║RunTime Analysis CS > 20ms > PS > 6ms > PE > 14ms > CE
+42ms ║Runtime (36949 bytes) successfully initialized in 6ms (v0.3.110.20191009) (40ms)
+44ms ║╔Execution stage started
+326ms ║║Comparison (boolean) true is (boolean) true = true (2ms)
+328ms ║║Condition #2 evaluated true (279ms)
+329ms ║║Condition group #1 evaluated true (state did not change) (281ms)
+332ms ║║Cancelling statement #3's schedules...
+351ms ║║Executed physical command Switch 6].on() (13ms)
+353ms ║║Executed [Switch 6].on (15ms)
+358ms ║╚Execution stage complete. (314ms)
+359ms ╚Event processed successfully (359ms)`Preformatted text`
