Does anyone know how to find all of the possible outcomes of " $twcweather.conditions.wxPhraseLong" ?
Is there another site, other than the weather wiki here, that gives more information about the $twcweather?
Thank you in advance.
Look here: https://wiki.webcore.co/TWC_Weather
the possible wxPhraseLong are somewhere near 3/4 down the page:
null,
âAM Clouds/PM Sunâ,
âAM Showersâ,
âClouds Early/Clearing Lateâ,
âCloudyâ,
âFog Lateâ,
âFoggyâ,
âMostly Clearâ,
âMostly Cloudyâ,
âMostly Sunnyâ,
âPartly Cloudyâ,
âPM Showersâ,
âPM Thunderstormsâ,
âRainâ,
âScattered Thunderstormsâ,
âShowersâ,
âShowers Earlyâ,
âShowers Lateâ,
âSunnyâ,
âThunderstormsâ,
âThunderstorms Earlyâ,
âThunderstorms Lateâ
I have not found any âofficialâ documents, so Iâve been adding to the wiki as I have time.
(I have over a thousand of these to go thru, which is 30,000 datapoints just for wxPhraseLong)
This undocumented $twcweather fiasco is really eating up my freetime, so if anyone finds any API documents from TWC, please share it with us, and save me my sanity, LOL
Wow⌠I didnât realize there were so many variables for this one. Thank you.
I will keep a look out for any documentation on this.
Well, most of the 30 thousand will be duplicates. I need to grab each cluster of text, remove duplicates, and alphabetize⌠Which is why itâs taking so long, LOL. I need to create a program to streamline it with so many data points.
If anyone knows of a text editor that can grab all the text between X and Y (over and over again moving down a giant document) and automatically paste it into another document, you would be a lifesaver, and our weather wiki would be nearly perfect within a few short days. (the copy/paste section is really the bottleneck for me at the moment. I already have tools in place for removing dups & sorting)
Awesome! I will add it to the wiki. Just to clarify, are there any spaces around the slash?
Ha! I already got a new one: âRain Shower/Windâ
I will try to start keeping a list of any new ones I see, and give them to you in a group, instead of one by one.
Excellent!
Give me a few hours, and I will create a new thread for contributions for all of the weather data. Anyone can add to it for any datapoint they discover, and I will keep the wiki updated with all of the new information. (this is kind of wise because there will likely never be snow in my location, so Iâd need contributions from a northerner to include those conditions as well)
A new thread has been created for undocumented datapoints.
Thank you all in advance for any contributions!!
Yes!! I figured it out!! So, this is why I was originally asking about the âwxPhraseLongâ.
Right now, I have IFTTT with WeatherUnderground turning Virtual Switches on/offâŚâWeather Clearâ; âWeather Cloudyâ; âWeather Rainâ; and âWeather Snowâ. Webcore will then turn certain lights from 0%, 10%, 50% depending on the switch that turned on.
IFTTT has been slow to report, and sometimes it will have been raining for 30 minutes already when the âWeather Rainâ finally kicks on.
So, Iâve been testing Webcore with the $twcweather⌠and I finally got some results.
Of course, this is just a test, but opens up so many possibilities.
I have another piston that is updating the variables.
Loving this!! And, itâs more accurate than with IFTTT and WeatherUnderground.
I will eventually have all of the outcomes of âwxPhraseLongâ added to 4 categories: Clear, Cloudy, Rain, Snow.
I will also be testing the Weather Alerts.
OhâŚand âShowers in Vicinityâ is another that I havenât added to the other thread just yet. I was hoping for a few more before posting.
Question: Iâm working on my Weather Alert piston. Right now, it sends an SMS to my phone when the $twcweather.alerts[0].eventDescription changes. But, it sends an SMS when an alert is activated, and then another âblankâ one when the alert goes away.
How do you tell webcore: When âvariableâ changes away from ânullâ ??
How do I tell it ânullâ ? No matter what I do, itâs not working. If I leave it blank, nothingâŚif I type ânullâ, nothingâŚ
How do you set the âchanges away from ânullââ? What do I type as the value?
Here is a snippet from my old WUnderground code:
Then do a bunch of stuffâŚ
and the last line of code is:
This piston will alert me on any changes, except for when it changes to nullâŚ
Notice the peculiar NOT in the IF section.
This is because there is no choice for: âis not equal toâ
So hereâs what I did, and it worked.
I defined a string at the start of the piston, âwCheckâ and left it blank.
Then in an IF, I said IF â$twcweather.alerts[0].eventDescriptionâ is equal to âwCheckâ, then set this variable to âNULLâ.
Now, I can use that in the piston I mentioned above, and say: IF this variable changes away from âNULLâ.
So cool the way you can work things out by playing around.
Hereâs what Iâm doing:
The first piston captures the weather attributes.
The second piston uses those attributes to send SMS messages.
