Trying to create a simple piston that calls a REST API POST method with JSON body.
The destination is a local IP address in my network for a Sony AV receiver. (API reference guide if needed: https://developer.sony.com/develop/audio-control-api/hardware-overview/api-references/svs/getplayingcontentinfo)
But the JSON appears to be getting modified somehow. Is there a way to log the Web Request to see exactly what it’s sending?
When I call the API with Postman, it returns a JSON object.
Something is happening to the POST’s JSON body within WebCoRE. The Sony receiver is returning “error”: [5,“Illegal JSON”]
I can reproduce this error message in Postman if I mess with the the body (like removing quotes around a parameter). So I’m pretty sure I’m not escaping characters properly here somewhere within my WebCoRE code. I also can’t figure out all the “Invalid ternary operator” errors no matter how many times I read the wiki post on it.
( 9:00:16 PM: trace ║╚ Execution stage started
9:00:16 PM: debug ║ RunTime Analysis CS > 89ms > PS > 102ms > PE > 94ms > CE
9:00:16 PM: trace ║╔ Execution stage complete. (5ms)
9:00:16 PM: debug ║ Calculating (string) version : (decimal) 1.2 >> (string)
9:00:16 PM: error ║ Invalid ternary operator. Ternary operator’s syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
9:00:16 PM: debug ║ Calculating (string) , (string) version >> (string) version
9:00:16 PM: debug ║ Calculating (string) params : (string) >> (string)
9:00:16 PM: debug ║ Calculating (string) , (string) params >> (string) params
9:00:16 PM: debug ║ Calculating (string) id : (integer) 1 >> (string)
9:00:16 PM: debug ║ Calculating (string) , (string) id >> (string) id
9:00:16 PM: debug ║ Calculating (string) method : (string) getPlayingContentInfo >> (string)
9:00:16 PM: debug ║ Calculating (string) output : (string) extOutput:zone?zone=1 >> (string)
9:00:16 PM: info ╚ Received event [hub].time = 1523246417388 with a delay of -1115ms
8:59:57 PM: info ║║ {“error”:[5,“Illegal JSON”]}
8:59:57 PM: debug ║ Calculating (string) version : (decimal) 1.2 >> (string)
8:59:57 PM: trace ║ Runtime (39943 bytes) successfully initialized in 52ms (v0.3.104.20180323) (144ms)
8:59:57 PM: debug ║ RunTime Analysis CS > 16ms > PS > 52ms > PE > 75ms > CE
8:59:57 PM: error ║ Invalid ternary operator. Ternary operator’s syntax is ( condition ? trueValue : falseValue ). Please check your syntax and try again.
8:59:57 PM: debug ║ Calculating (string) , (string) version >> (string) version
8:59:57 PM: debug ║ Calculating (string) , (string) params >> (string) params
8:59:57 PM: debug ║ Calculating (string) id : (integer) 1 >> (string)
8:59:57 PM: debug ║ Calculating (string) params : (string) >> (string)
8:59:57 PM: debug ║ Calculating (string) , (string) id >> (string) id
8:59:57 PM: debug ║ Calculating (string) method : (string) getPlayingContentInfo >> (string)
8:59:57 PM: debug ║ Calculating (string) output : (string) extOutput:zone?zone=1 >> (string)
8:59:57 PM: info ╚ Received event [Hermosa].wc_async_reply = httpRequest with a delay of 0ms
8:59:57 PM: debug ║║ Sending internal web request to: local.ip.add.ress:10000/sony/system
8:59:57 PM: debug ║║ Cancelling statement #1’s schedules…
8:59:57 PM: info ║ Setting up scheduled job for Sun, Apr 8 2018 @ 9:00:17 PM PDT (in 19.973s)
8:59:57 PM: trace ║╚ Execution stage started
8:59:57 PM: info ╚ Received event [hub].test = 1523246397080 with a delay of 3ms
