I’m trying to create a piston that turns on a switch when on one of my ST sensors is 17 degrees or below. But I only want this to happen between a set time each morning and for the switch to turn off once it is outside of this bracket.
I’ve attached my attempt, but I’m a little confused by all of the many options and definitions. Could someone help me understand if what I’m doing is correct, perhaps someone could also help me understand how to use ‘else-if’ command in layman’s terms? I’ve Googled a few explanations but I’m still finding it a little confusing unfortunately…
Many thanks for your help
(UPLOAD YOUR IMAGE HERE)
