Ya beat me to it! I had mine originally built with the simple yes/no responses. But, as you said, since then, Alexa reserved “yes” and “no” for their use. - making those no longer function properly. Now I use “Yes please” and “No thank you” as appropriate. Works just like the original intent.
WebCoRE asks a question, my voice response determines the action
Ahhh okay - I missed that part so my apologies and thank you for pointing it out. I’ve got it working now! Time to start adding more of them!
While I am thinking of it, I’d like to make a call out to the community:
If anyone can suggest a one syllable word to represent “Yes” and “No”, I would love some ideas and feedback here. My goal is to keep the phrase as short as possible, yet somewhat natural.
I am debating using “True” and “False”. I could reword my questions a bit to match.
IE:
webCoRE asks, “The trash is already at the street… True or false?”
I respond, “Alexa, False”
webCoRE speaks, “Don’t wait too long… There’s a 45% chance of rain in an hour”
Any other mono-syllabic ideas besides “True” and “False”…??
For the record, we can make duplicate Routines in Alexa, that all do the same thing, using a different phrase. It takes a tiny bit extra time to make those extra Routines, but it allows for anyone in the family to use an answer that fits them.
So, for example, let’s say the household has Proper Patricia, Binary Billy, Military Michelle and Surfer Stanley… The following four phrases (Routines) can all turn on “Answer Yes”
- Alexa, Yes please
- Alexa, True
- Alexa, Affirmative
- Alexa, Far out!
Along the same lines, I could make four Routines to turn on “Answer No”
- Alexa, No thanks
- Alexa, False
- Alexa, Negative
- Alexa, Gnarly
If we are creative here, the same two SimSwitches can handle many types of questions…
(even beyond the typical Yes/No variety).
If you already have the Routines created (as my first post), then the quickest way to do this is:
Phone > Alexa App > Hamburger menu > Routines > “Alexa, yes please” > Three dot menu >
Then, all you have to do is use a different phrase. I just tested half of these phrases, and they properly turned on the correct SimSwitch. Many other words or phrases will also work, which means that our questions can actually get much more complex. (as long as we keep in mind the 3 possible outcomes)
I’d still love to hear some alternative short phrases, if anyone thinks of any…
My phrases are kind of long but they seem to work. I just tell the person what to say.
I just add the command that needs to be said. My wife can never remember what I tell here to say, so Alexa tells us after the question is asked.
Plus I always make the more common response as the default so you don’t have to say anything.
True and False seems ok to.
Now that I am using Echo Speaks and can determine which Echo device I am talking to, and which device should respond, this opens up a whole new world of possibilities. @WCmore, thank you sir!
I had installed Echo Speaks on my Hubitat hub awhile back but since I am still running my ST hub as a remote to my HE hub, I left most of the Echo speaks stuff on it.
Yesterday I finally moved over the pistons from ST to Hubitat that determine which device you speak to. My ceiling fan routine which generally took about 15 to 20 seconds to respond in ST takes 5 seconds on a Hubitat hub.
I thought that delay was because Alexa does not report that info in a timely manner.
(meaning, I thought it was entirely outside of webCoRE’s influence)
Oh right… Different command… Different delay…
(which should be the same in Hubitat, I imagine)
I think we already had this discussion. As I said in the other thread, I call a common piston with getDeviceActivity, then have a global set that the calling piston uses to determine which device. The biggest delay was getting the global updated between pistons. That seems much faster in HE.
This is AWESOME, just what I was looking for for a long while.
I made it work with google home… does anyone know if it is possible to have google listens after it speaks. so i dont have to say the words “hey google”
in webcore i can only see “speak”, if only there was a “listen” option
Thanks alot
I had fun creating this one… Glad you got some use out of it too!
Not that I know of. (although it is always listening for the “wake words”)
Well, I’ll just have it say ok Google after it finishes the question. That way I only have to yes or no
(Until ofcourse someone figures out a way)
Alexa and Google (like humans) cannot talk and listen at the same time…
… but if you have two speakers near each other, then one is able to talk to the other.
Make it a little more fun by creating custom routines. For example, “Ok google, that’s an affirmative.” Turns on the on switch.
Yeah. I have (affirmative, yup, yes please) for yes
And (negative, nope, no please) for no
