Does WebCore work with the latest Smartthings IOS app and IDE? If so, where can i get instructions and the code to install WebCore?
yes but the question is how much longer it will be available on the ST platform so you may not want to build too many pistons at this point.
The instructions for installing the code in IDE is listed in the following thread. The one part that is out-of-date is setting up webcore in the ST app. Where it listed go to MarketPlace, now go to the Automations section, click on Add Routine, tap on the Discover tab near the top of the screen, then scroll down to find webcore. After you set it up, it will appear on the main Automations section. I doubt if you can access the Dashboard from within the ST app at this point but will need to access it from a browser or the webcore app on a tablet or phone.
But again, it appears ST may be getting to the point where they are going to start winding down the legacy part of the platform and that means WebCoRE and Smart Lighting will cease when the migration from groovy to Edge and LUA is finished
