Hi I recently moving my pistons from ST webcore to HE webcore
even the version seems to be the same, some pistons give me a warning on the configuration that the same piston in ST did not have.
Also noticed that triggers names are different however I managed to find some equivalents
Could you please tell me if the warnings are something I should be concerned about ?
As I say there was never warnings on these pistons running in ST
Thank you
Webcore differences after pistons migrated from ST to HE
Martin
E_Sch
Those are the same trigger comparisons. The labeling has been adjusted to what the implementation was/is in webCoRE
See:
Martin
Eric , thank you very much for you response, it is much more clear to me now.
I will review the pistons and do the proper corrections if necessary . I will consider this for future pistons , Thank you
