My piston turns on a light when triggered by motion then back off 90 seconds after motion stops. Sometimes it will not process a motion event shortly after turning the light off.
The piston should always fire when motion is detected.
Logs show that motion is seen but the piston does not fire.
The piston may look complex but I use this logic in several pistons and I’m a bit OCD.
Hubitat logs:
webCore logs:
