WebCore expression problem
When I try to set a local variable to an expression, webcore will not allow anything to be entered in the expression field. Instead, it shows three dots, then (Evaluating), then 0 Anyone encountered this? Thanks.
A screenshot might help
… Also the variable type impacts the possible outcome. If you choose “Dynamic” then you are giving up control and hoping webCoRE interprets your expression correctly.
(personally, I rarely use Dynamic)
You can see a great example of “0” interpreted differently here.
