The piston works but with semaphores. This piston calculates the appropriate Location Mode (Home, Away or Vacation) based on our iPhones’ distance from home with the webCoRE presence capabilities and the @AwayCircle and @VacCircle global variables. It then ‘presses’ the appropriate simulated ‘Location Mode’ switch - which causes the ‘Location Modes Actuator’ Piston to run. The ‘Location Modes Actuator’ Piston changes both the Location Mode and the associated Thermostat Heat/Cool Set Points. Further, since the ‘T-Stat Schedule’ Piston can only make thermostat setpoint changes when the Location Mode is ‘Home’, changing the Location Mode to ‘Away’ or ‘Vacation’ effectively places thermostat setpoint changes on hold until the Location Mode is set back to ‘Home’ again.
No/Less semaphores if possible. I think the semiphores are happening due to the frequent feedback from the phones regarding their location. I had originally had written this to only trigger when both phones crossed a linie (Away or Vacation). However, since the two phones never cross the lines at the same time, it never worked that way. So, I changed it to check for the phones being in a particular range . This requires BOTH phones to be in a range when when moving away from home and ANY phone when getting closer to home. This is so that the closest range to home is calculated.
See above
2/25/2020, 9:39:16 AM +845ms
+1ms ╔Received event [Lee].distance = 0.01958875750529802 with a delay of 101ms
+10183ms ║RunTime Analysis CS > 23ms > PS > 10110ms > PE > 51ms > CE
+10184ms ║Piston waited at a semaphore for 10079ms
+10187ms ║Runtime (53163 bytes) successfully initialized in 10110ms (v0.3.110.20191009) (10185ms)
+10188ms ║╔Execution stage started
+10206ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+10208ms ║║Condition #6 evaluated false (14ms)
+10218ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (1ms)
+10221ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (1ms)
+10222ms ║║Condition #26 evaluated false (13ms)
+10224ms ║║Condition group #25 evaluated false (state did not change) (14ms)
+10225ms ║║Condition group #24 evaluated false (state did not change) (31ms)
+10226ms ║║Condition group #1 evaluated false (state did not change) (33ms)
+10237ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (1ms)
+10239ms ║║Condition #12 evaluated false (11ms)
+10240ms ║║Condition group #7 evaluated false (state did not change) (12ms)
+10253ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+10255ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+10257ms ║║Condition #22 evaluated false (14ms)
+10258ms ║║Condition group #19 evaluated false (state did not change) (16ms)
+10270ms ║║Comparison (decimal) 0.01958875750529802 is_less_than (integer) 5 = true (1ms)
+10271ms ║║Condition #18 evaluated true (10ms)
+10276ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (2ms)
+10277ms ║║Condition #17 evaluated false (5ms)
+10278ms ║║Condition group #13 evaluated false (state did not change) (17ms)
+10280ms ║╚Execution stage complete. (92ms)
+10281ms ╚Event processed successfully (10281ms)
2/25/2020, 9:39:16 AM +800ms
+1ms ╔Received event [Lee].distance = 0.01958875750529802 with a delay of 104ms
+10153ms ║RunTime Analysis CS > 20ms > PS > 10069ms > PE > 65ms > CE
+10154ms ║Piston waited at a semaphore for 10040ms
+10157ms ║Runtime (53163 bytes) successfully initialized in 10069ms (v0.3.110.20191009) (10155ms)
+10158ms ║╔Execution stage started
+10176ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+10178ms ║║Condition #6 evaluated false (15ms)
+10188ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (1ms)
+10191ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (2ms)
+10193ms ║║Condition #26 evaluated false (12ms)
+10194ms ║║Condition group #25 evaluated false (state did not change) (13ms)
+10195ms ║║Condition group #24 evaluated false (state did not change) (31ms)
+10196ms ║║Condition group #1 evaluated false (state did not change) (33ms)
+10206ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (1ms)
+10207ms ║║Condition #12 evaluated false (9ms)
+10208ms ║║Condition group #7 evaluated false (state did not change) (10ms)
+10220ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+10223ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+10224ms ║║Condition #22 evaluated false (13ms)
+10225ms ║║Condition group #19 evaluated false (state did not change) (15ms)
+10237ms ║║Comparison (decimal) 0.01958875750529802 is_less_than (integer) 5 = true (1ms)
+10239ms ║║Condition #18 evaluated true (10ms)
+10243ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (2ms)
+10244ms ║║Condition #17 evaluated false (5ms)
+10245ms ║║Condition group #13 evaluated false (state did not change) (17ms)
+10247ms ║╚Execution stage complete. (89ms)
+10248ms ╚Event processed successfully (10248ms)
2/25/2020, 9:39:24 AM +345ms
+2ms ╔Received event [Lee].distance = 0.010905761747191153 with a delay of 105ms
+121ms ║RunTime Analysis CS > 26ms > PS > 30ms > PE > 64ms > CE
+124ms ║Runtime (53085 bytes) successfully initialized in 30ms (v0.3.110.20191009) (121ms)
+143ms ║║Comparison (decimal) 0.010905761747191153 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+145ms ║║Condition #6 evaluated false (14ms)
+155ms ║║Comparison (decimal) 0.010905761747191153 is_greater_than (integer) 50 = false (1ms)
+158ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (1ms)
+159ms ║║Condition #26 evaluated false (13ms)
+160ms ║║Condition group #25 evaluated false (state did not change) (14ms)
+161ms ║║Condition group #24 evaluated false (state did not change) (30ms)
+162ms ║║Condition group #1 evaluated false (state did not change) (32ms)
+173ms ║║Comparison (decimal) 0.010905761747191153 is_greater_than (integer) 50 = false (2ms)
+174ms ║║Condition #12 evaluated false (9ms)
+175ms ║║Condition group #7 evaluated false (state did not change) (10ms)
+186ms ║║Comparison (decimal) 0.010905761747191153 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+189ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+191ms ║║Condition #22 evaluated false (12ms)
+192ms ║║Condition group #19 evaluated false (state did not change) (14ms)
+202ms ║║Comparison (decimal) 0.010905761747191153 is_less_than (integer) 5 = true (1ms)
+204ms ║║Condition #18 evaluated true (9ms)
+208ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (2ms)
+209ms ║║Condition #17 evaluated false (5ms)
+210ms ║║Condition group #13 evaluated false (state did not change) (16ms)
+212ms ║╚Execution stage complete. (87ms)
+213ms ╚Event processed successfully (213ms)
2/25/2020, 9:39:23 AM +309ms
+2ms ╔Received event [Lee].distance = 0.0057985429684405225 with a delay of 111ms
+109ms ║RunTime Analysis CS > 27ms > PS > 32ms > PE > 50ms > CE
+112ms ║Runtime (53083 bytes) successfully initialized in 32ms (v0.3.110.20191009) (110ms)
+130ms ║║Comparison (decimal) 0.0057985429684405225 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+132ms ║║Condition #6 evaluated false (14ms)
+141ms ║║Comparison (decimal) 0.0057985429684405225 is_greater_than (integer) 50 = false (1ms)
+144ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (1ms)
+145ms ║║Condition #26 evaluated false (12ms)
+146ms ║║Condition group #25 evaluated false (state did not change) (13ms)
+147ms ║║Condition group #24 evaluated false (state did not change) (30ms)
+148ms ║║Condition group #1 evaluated false (state did not change) (31ms)
+158ms ║║Comparison (decimal) 0.0057985429684405225 is_greater_than (integer) 50 = false (1ms)
+159ms ║║Condition #12 evaluated false (9ms)
+160ms ║║Condition group #7 evaluated false (state did not change) (10ms)
+171ms ║║Comparison (decimal) 0.0057985429684405225 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+173ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+175ms ║║Condition #22 evaluated false (13ms)
+176ms ║║Condition group #19 evaluated false (state did not change) (13ms)
+185ms ║║Comparison (decimal) 0.0057985429684405225 is_less_than (integer) 5 = true (1ms)
+187ms ║║Condition #18 evaluated true (9ms)
+191ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (1ms)
+192ms ║║Condition #17 evaluated false (5ms)
+193ms ║║Condition group #13 evaluated false (state did not change) (15ms)
+195ms ║╚Execution stage complete. (81ms)
+196ms ╚Event processed successfully (195ms)
2/25/2020, 9:39:22 AM +389ms
+1ms ╔Received event [Lee].distance = 0.00516319961353673 with a delay of 113ms
+234ms ║RunTime Analysis CS > 29ms > PS > 152ms > PE > 54ms > CE
+237ms ║Runtime (53085 bytes) successfully initialized in 152ms (v0.3.110.20191009) (235ms)
+238ms ║╔Execution stage started
+255ms ║║Comparison (decimal) 0.00516319961353673 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+257ms ║║Condition #6 evaluated false (14ms)
+268ms ║║Comparison (decimal) 0.00516319961353673 is_greater_than (integer) 50 = false (1ms)
+270ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (1ms)
+272ms ║║Condition #26 evaluated false (14ms)
+273ms ║║Condition group #25 evaluated false (state did not change) (15ms)
+274ms ║║Condition group #24 evaluated false (state did not change) (31ms)
+275ms ║║Condition group #1 evaluated false (state did not change) (33ms)
+286ms ║║Comparison (decimal) 0.00516319961353673 is_greater_than (integer) 50 = false (1ms)
+288ms ║║Condition #12 evaluated false (10ms)
+289ms ║║Condition group #7 evaluated false (state did not change) (11ms)
+301ms ║║Comparison (decimal) 0.00516319961353673 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+304ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+306ms ║║Condition #22 evaluated false (15ms)
+307ms ║║Condition group #19 evaluated false (state did not change) (16ms)
+318ms ║║Comparison (decimal) 0.00516319961353673 is_less_than (integer) 5 = true (2ms)
+320ms ║║Condition #18 evaluated true (9ms)
+324ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (2ms)
+325ms ║║Condition #17 evaluated false (5ms)
+326ms ║║Condition group #13 evaluated false (state did not change) (17ms)
+328ms ║╚Execution stage complete. (90ms)
+329ms ╚Event processed successfully (330ms)
2/25/2020, 9:39:20 AM +522ms
+1ms ╔Received event [Lee].distance = 0.017139259181741306 with a delay of 104ms
+103ms ║RunTime Analysis CS > 27ms > PS > 29ms > PE > 47ms > CE
+106ms ║Runtime (53083 bytes) successfully initialized in 29ms (v0.3.110.20191009) (104ms)
+123ms ║║Comparison (decimal) 0.017139259181741306 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+125ms ║║Condition #6 evaluated false (13ms)
+134ms ║║Comparison (decimal) 0.017139259181741306 is_greater_than (integer) 50 = false (1ms)
+136ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (2ms)
+137ms ║║Condition #26 evaluated false (11ms)
+138ms ║║Condition group #25 evaluated false (state did not change) (12ms)
+139ms ║║Condition group #24 evaluated false (state did not change) (28ms)
+140ms ║║Condition group #1 evaluated false (state did not change) (29ms)
+150ms ║║Comparison (decimal) 0.017139259181741306 is_greater_than (integer) 50 = false (1ms)
+152ms ║║Condition #12 evaluated false (9ms)
+153ms ║║Condition group #7 evaluated false (state did not change) (11ms)
+164ms ║║Comparison (decimal) 0.017139259181741306 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+166ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+168ms ║║Condition #22 evaluated false (13ms)
+169ms ║║Condition group #19 evaluated false (state did not change) (14ms)
+179ms ║║Comparison (decimal) 0.017139259181741306 is_less_than (integer) 5 = true (1ms)
+180ms ║║Condition #18 evaluated true (9ms)
+184ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (1ms)
+185ms ║║Condition #17 evaluated false (4ms)
+186ms ║║Condition group #13 evaluated false (state did not change) (15ms)
+188ms ║╚Execution stage complete. (81ms)
+189ms ╚Event processed successfully (189ms)
2/25/2020, 9:39:16 AM +781ms
+1ms ╔Received event [Lee].distance = 0.01958875750529802 with a delay of 114ms
+121ms ║RunTime Analysis CS > 33ms > PS > 37ms > PE > 51ms > CE
+124ms ║Runtime (53082 bytes) successfully initialized in 37ms (v0.3.110.20191009) (122ms)
+142ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+144ms ║║Condition #6 evaluated false (13ms)
+155ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (1ms)
+157ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (1ms)
+159ms ║║Condition #26 evaluated false (14ms)
+160ms ║║Condition group #25 evaluated false (state did not change) (15ms)
+161ms ║║Condition group #24 evaluated false (state did not change) (31ms)
+162ms ║║Condition group #1 evaluated false (state did not change) (33ms)
+173ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (2ms)
+174ms ║║Condition #12 evaluated false (10ms)
+175ms ║║Condition group #7 evaluated false (state did not change) (11ms)
+187ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+189ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+191ms ║║Condition #22 evaluated false (13ms)
+203ms ║║Comparison (decimal) 0.01958875750529802 is_less_than (integer) 5 = true (1ms)
+208ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (1ms)
+210ms ║║Condition #17 evaluated false (4ms)
+211ms ║║Condition group #13 evaluated false (state did not change) (16ms)
2/25/2020, 9:39:16 AM +308ms
+1ms ╔Received event [Lee].distance = 0.01958875750529802 with a delay of 110ms
+114ms ║RunTime Analysis CS > 32ms > PS > 34ms > PE > 49ms > CE
+117ms ║Runtime (53083 bytes) successfully initialized in 34ms (v0.3.110.20191009) (115ms)
+136ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+139ms ║║Condition #6 evaluated false (15ms)
+151ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (2ms)
+154ms ║║Comparison (decimal) 0.013600698207647786 is_greater_than (integer) 50 = false (2ms)
+156ms ║║Condition #26 evaluated false (16ms)
+157ms ║║Condition group #25 evaluated false (state did not change) (17ms)
+159ms ║║Condition group #24 evaluated false (state did not change) (35ms)
+160ms ║║Condition group #1 evaluated false (state did not change) (38ms)
+173ms ║║Comparison (decimal) 0.01958875750529802 is_greater_than (integer) 50 = false (1ms)
+175ms ║║Condition #12 evaluated false (12ms)
+176ms ║║Condition group #7 evaluated false (state did not change) (13ms)
+189ms ║║Comparison (decimal) 0.01958875750529802 is_inside_of_range (integer) 5 … (integer) 50 = false (1ms)
+192ms ║║Comparison (decimal) 0.013600698207647786 is_inside_of_range (integer) 5 … (integer) 50 = false (2ms)
+194ms ║║Condition #22 evaluated false (15ms)
+195ms ║║Condition group #19 evaluated false (state did not change) (16ms)
+206ms ║║Comparison (decimal) 0.01958875750529802 is_less_than (integer) 5 = true (1ms)
+208ms ║║Condition #18 evaluated true (10ms)
+212ms ║║Comparison (string) :cf8423e7dfeccd9432227c2ce2fa3008: is (string) :5f1ef659f5fd1e1805884f942e292500: = false (2ms)
+213ms ║║Condition #17 evaluated false (4ms)
+214ms ║║Condition group #13 evaluated false (state did not change) (16ms)
+216ms ║╚Execution stage complete. (98ms)
+217ms ╚Event processed successfully (217ms)
