Yes! I think I explained in the instructions somewhere. You have to make a separate project in google script because the name of the scripts are the same. As long as they both point to the same spreadsheet, you can add and read. I just have a @URLwriteScript and @URLreadScript variable for accessing from any piston.
Unfortunately, I did not figure out how to overwrite entire rows but I did create a script to replace individual values. You have to specify row, column, and value [in addition to tab if not default] and you can only do one value per call. [I tried multiple but for some reason, the parameters did not go to google script in the same order I listed them-bug?] I have a @URLreplaceScript for accessing this one.
Here is the script:
// version 2.0 - Guxdude
function doGet(request) {
  if(request != null) {
    var spreadSheet = SpreadsheetApp.openById("YOUR ID HERE");
    // default tab name
    var sheet = spreadSheet.getSheetByName("Testing");
    var firstRowRange = sheet.getRange(1, 1, 1, sheet.getLastColumn());
    var sheetHeaders=firstRowRange.getValues();
    // No default column name. If none provided, entire sheet will be returned
    var columnName = "";
    var colFound=false;
    var columnNumber = -1;
    var rowNumber = -1;
    //var firstDate=-1;
    //var lastDate=-1;
    //var firstRow=0;
    //var lastRow=0;
    var range;
    var newValue;
    var selectRow=1;
    var selectCol=1;
    var nRows=1;
    var nCols=1;
    //var tt=request.queryString;
    Logger.log(request.parameters)
    // Evaluate all the query parameters
    for (var i in request.parameters) {
      var paramName = i.toString();
      var paramValue = request.parameter[i];
      switch(paramName) {
        case "XtabX":
          // select specified tab by name and get new first row data
          Logger.log("tab name is %s",paramValue);
          sheet = spreadSheet.getSheetByName(paramValue);
          break;
        case "colName":
          // If colName parameter is found, search for that column
          columnName = paramValue.toString().toLowerCase();
          break;
        case "colNum":
          columnNumber=Number(paramValue);
          Logger.log("row is %d", rowNumber);
          break;
        case "rowNum":
          rowNumber=Number(paramValue);
          break;
        case "Value":
          newValue=paramValue;
          Logger.log("value is %s", newValue);
          break;
        default:
          // Unrecognized parameter: ignore
    if (columnNumber<0) {
    // Parameters do not seem to be in order so have to evaluate all before setting
      Logger.log("column name is %s", columnName);
      colFound=false;
      for(var x=0;x<sheetHeaders[0].length;x++) {
        Logger.log(sheetHeaders[0][x].toString().toLowerCase())
        if(columnName==sheetHeaders[0][x].toString().toLowerCase()) {
          columnNumber=x+1;
          colFound=true;
          break;
      if (colFound==false) {columnNumber=-1; Logger.log("column not found"); }
    if (rowNumber>0 && columnNumber>0) {
      // set value
      sheet.getRange(rowNumber, columnNumber).setValue(newValue);
      Logger.log("Setting value %s", newValue);
      //range = sheet.getRange(selectRow,selectCol,nRows,nCols);
    // get data values from specified range
    // var data = range.getValues();
    //return data in JSON format
    //return sheet.getRange(rowNumber, columnNumber).getValue().toString();
    return ContentService.createTextOutput(JSON.stringify(sheet.getRange(rowNumber, columnNumber).getValue())).setMimeType(ContentService.MimeType.JSON);
