Thanks. I’ve updated my script and got everything I need. I simplified the way the URL is created and made it easier on myself.
WebCoRE logging to Google Sheets with multiple tabs
Great! Yes, I find putting it together in pieces makes it clearer. Glad you got it working. Was hoping someone would try it so I knew it worked for someone other than me
Any chance someone could provide an example Piston? (The more thorough the better).
I’ve been able to successfully create the other solutions mentioned by the OP, but am having trouble with the global veritable and how to structure/format correctly in WC.
Must thanks!
@JJJSchmidt, Here is an example I put together a little while ago…
You asked about the global variables. They both have the format
string @URLReadScript = https://script.google.com/macros/s/MYPRIVATEKEY/exec
And then I use them as seen above in the pistons.
I prefer to just use Google Forms to write logs. Takes minutes to build a form and link the responses to a Google sheet.
A simple web request to the form is then all you need.
Example, make a web request to:
https://docs.google.com/forms/d/e/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/formResponse?usp=pp_url&entry.922906038={yourData1}&entry.760865007={yourData2}&entry.1343069662={yourData3}&entry.1032338001={yourData4}&submit=Submit
To write to multiple tabs, just create a different Google Form and link it to the relevant tab.
When building a Google Form there is an option in the hamburger menu to ‘get pre-filled link’, use this to get the base format of the URL and add &submit=Submit
on the end.
Has anyone got this to work?
@Robin
I can get the URL to work and believe its just the “&submit=Submit” added to the end that’s not working.
because If I just past the URL without the “&submit=Submit” into a browser the form pops up with the correct answers entered. then I just have to click on the Submit to enter it.
I figured it out!!!
I also needed to add formResponse? in place of the viewform? of the pre-filled link so it matches the above Example.
Odd behavior with writing to my test Google Sheet.
No output or log created after clicking “Test” with Full logging on.
I am getting partial output to my test google sheet. But I am only getting 9 rows, and the first should be “0”.
It could be writing too fast in a loop like this. Try adding a 3 or 5 second wait between writes. Also, if you make the first column “Date”, then the date and time of each log will automatically be added.
Yes! I think I explained in the instructions somewhere. You have to make a separate project in google script because the name of the scripts are the same. As long as they both point to the same spreadsheet, you can add and read. I just have a @URLwriteScript and @URLreadScript variable for accessing from any piston.
Unfortunately, I did not figure out how to overwrite entire rows but I did create a script to replace individual values. You have to specify row, column, and value [in addition to tab if not default] and you can only do one value per call. [I tried multiple but for some reason, the parameters did not go to google script in the same order I listed them-bug?] I have a @URLreplaceScript for accessing this one.
Here is the script:
// version 2.0 - Guxdude
function doGet(request) {
if(request != null) {
var spreadSheet = SpreadsheetApp.openById("YOUR ID HERE");
// default tab name
var sheet = spreadSheet.getSheetByName("Testing");
var firstRowRange = sheet.getRange(1, 1, 1, sheet.getLastColumn());
var sheetHeaders=firstRowRange.getValues();
// No default column name. If none provided, entire sheet will be returned
var columnName = "";
var colFound=false;
var columnNumber = -1;
var rowNumber = -1;
//var firstDate=-1;
//var lastDate=-1;
//var firstRow=0;
//var lastRow=0;
var range;
var newValue;
var selectRow=1;
var selectCol=1;
var nRows=1;
var nCols=1;
//var tt=request.queryString;
Logger.log(request.parameters)
// Evaluate all the query parameters
for (var i in request.parameters) {
var paramName = i.toString();
var paramValue = request.parameter[i];
switch(paramName) {
case "XtabX":
// select specified tab by name and get new first row data
Logger.log("tab name is %s",paramValue);
sheet = spreadSheet.getSheetByName(paramValue);
break;
case "colName":
// If colName parameter is found, search for that column
columnName = paramValue.toString().toLowerCase();
break;
case "colNum":
columnNumber=Number(paramValue);
Logger.log("row is %d", rowNumber);
break;
case "rowNum":
rowNumber=Number(paramValue);
break;
case "Value":
newValue=paramValue;
Logger.log("value is %s", newValue);
break;
default:
// Unrecognized parameter: ignore
if (columnNumber<0) {
// Parameters do not seem to be in order so have to evaluate all before setting
Logger.log("column name is %s", columnName);
colFound=false;
for(var x=0;x<sheetHeaders[0].length;x++) {
Logger.log(sheetHeaders[0][x].toString().toLowerCase())
if(columnName==sheetHeaders[0][x].toString().toLowerCase()) {
columnNumber=x+1;
colFound=true;
break;
if (colFound==false) {columnNumber=-1; Logger.log("column not found"); }
if (rowNumber>0 && columnNumber>0) {
// set value
sheet.getRange(rowNumber, columnNumber).setValue(newValue);
Logger.log("Setting value %s", newValue);
//range = sheet.getRange(selectRow,selectCol,nRows,nCols);
// get data values from specified range
// var data = range.getValues();
//return data in JSON format
//return sheet.getRange(rowNumber, columnNumber).getValue().toString();
return ContentService.createTextOutput(JSON.stringify(sheet.getRange(rowNumber, columnNumber).getValue())).setMimeType(ContentService.MimeType.JSON);
It may be my programming, but it appears that the new write script is writing blanks to the sheet. I’ll continue to debug. Please check my syntax.
Sorry, for the overwrite script, the parameters are: XtabX, Value, colName, colNum, and rowNum. You can specify either the column name using colNum or column number using colNum but not both. If colNum is supplied, ColName will be ignored. So I think the parameters you want are:
“&XtabX=Sheet1&colNum=1&rowNum=” Row_Number “&Value=” Foods[$index]
or
“&XtabX=Sheet1&colName=Fruit&rowNum=” Row_Number “&Value=” Foods[$index]
Either should work.
@Pantheon, NOTE: Right now I am having trouble reading anything from google sheets using my script. Seems to be a redirect issue with the latest webcore update. Writing still seems to work fine.
@guxdude, this project is awesome. I am going to be able to use your scripts to do several things. However, at this time, my READ is working, but my WRITE is not. It is probably related to the redirect issue you mentioned.
Which write are you having trouble with? The one to overwrite a cell or the one for general logging that just adds a new row each time?
My OVERWRITE is not working. Not sure if it is my syntax or not. I have tried multiple iterations of syntax in the OVERWRITE script and nothing seems to work. My READ and WRITE work fine.
