when i create a piston depending on the piston i guess (doesn’t happen with all), i make the piston and press save. The piston saves like it should but when i trigger the piston, the piston doesn’t fire. If i go back into the piston, press edit (not make any changes) then press save, the piston will work the next time it supposed to and will work fine until i make a change to it again, then i’ll have to go back into the piston, press edit and save to get it working. I don’t understand why it does that.
Create and save the piston and the piston should work without having to press edit and save again.
Piston does not work until i press edit and save.
